i have a pontiac sunbird that i believe is getting too much fuel it emits black smoke, it idles real rough and when you put it in gear it stalls out when i actually drove it the other day i went throug hhalf a taank of gas in about 30 miles and could only go about 20 mph any ideas what could be causing this i cant afford to take it to a garage and do most repairs myself just have a hard time diagnosing things
Re: sunbird getting too much fuel
The year and engine size would be helpful. Did the check engine light come on at all?
When running rough, does it backfire out the intake or exhaust at all. Or does it just sound like a "miss". Probably don't doubt that your plugs are fouling out with all that gas. |
Definitely burning a bit rich?
![]() I actually have a 1994 Sunbird with the Fuel injected 2.0 L4 Sohc that has a similar problem. The exhaust has Black smoke coming out of it and I know it is flooding with Fuel. It gives off the sound of a miss like a plug problem would. I have pulled off the CAT Conv. Replaced the Fuel Filter, Way more of a Problem after changing. Also Replaced; Sparkplugs Wires Map Sensor (Pulled off Junkyard car, No change in problem, Maybe Bad?) Checked gas for water Changed all Fluids, Inc flushing cooling system (Not related to this problem) Also No Gas or water in Oil. |
check spark make sure is white or blue
check idle solenoid motor clean it EGR valve ? pressure regulator stuck ? pull the hose off it and see if wet if so then its ruptured inside
I also am user fastr68 here- Randy -'54 F100 302 C-6 -'57 F100 -'57 Bel Air HT 307 4spd '57 210 HT 4dr 265 3spd -'68 corvair monza convertible w/ PG -'79 C-20 -'80 K-20 -'82 K-10 SS -'82 TRANS AM WS7 HT 5.0L TH350 2400 stall blue/blue level III PMD cloth PG hood -'85 Elky SS 310ci 2004r fully restored 2008 -'88 buick century estate wagon 3800 4t40e, 91 s-10 2wd 4.3L, 96 taurus, '97 cavalier RS 2.2L, 5sd -'05 18ft car trailer, 98 achieva, 98 cherokee, |
