Go Back   Automotive Forums Car Chat > Saturn > SC/SL/SW
Old 05-08-2006, 11:49 PM
Ridleyj329 Ridleyj329 is offline
cooling fan always on.
i have a 94 sl1 sohc. the previous owner before me had the fan rewired so that its always on. does anyone know where i could find an online wire schematic to fix this or would anyone be able to explain how?
Old 05-09-2006, 12:44 AM
sierrap615 sierrap615 is offline
Master Tech Wanna-be
Re: cooling fan always on.
only god knows how he wired it. i can guess he did this because the fan wasn't coming on when he thought it should, which it a common side effect of a bad ECT (http://www.saturnfans.com/forums/showthread.php?t=24003)
if the wiring was correct, this is a diagnosis for a fan no run - http://www.saturnfans.com/forums/showthread.php?t=41736
here is how to install a manual fan switch - http://www.saturnfans.com/forums/showthread.php?t=23668
with that thread you may be able to get a idea for the wiring. if i was to override a fan, i would short out the relay, most people however would cut and hack into the wires to the fan. first start by visually inspecting the wiring loom for obivuos alterations.
Daily driver: 1995 Buick Regal Custom 3.8L 4T60-E 150K miles
Gone: 1994 Saturn SL2 1.9L MP3 168,666 miles
EPA 608 Universal Certification
EPA 609 Certification
Old 05-09-2006, 01:07 AM
if i do a manual switch itll be hard to tell if the things connecting to the fan are woking properly
Old 05-09-2006, 01:23 AM
have you wire a diagram so that i can rewire it correctly?
