Go Back   Automotive Forums Car Chat > Oldsmobile > Aurora
Closed Thread Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 05-08-2006, 11:40 PM
Smoothe LJ Smoothe LJ is offline
dreadful maf sensor!!!!!!!
OK so i thake my car to tha shop and i get it back runnin like crap. i take it back and he says my maf sensor is going bad and it's throwing that code. so he replaces it and i get my baby back. drives like a brand new car (happened to drive it all day about 6 hrs.) next morinin i get up to go to work and my car starts and shuts off immediately. This happens everyday for bout 4 days then 2 days after sittin i finally get a chance to take it back so i call tow truck guy. truck guy arrive get in tha car and it starts right up. so now im thinking i should pop ur tires and make her suffer j/k. so i let tha guy tow it anyway and tha mechanic says it throwing that code again so he gets ne maf sensor and drives it and it;s runnin fine then i go to pick up and it wont start again. apparently this car hates me! and now it's throwing that code again if there any insite on whats going on PLEASE HELP it would be greatly appreciated!!!!!!
Old 05-09-2006, 09:15 PM
zimaad zimaad is offline
Re: dreadful maf sensor!!!!!!!
Ok, when you say it won't start, does that mean no juice, no anything or does it crank just not turn over? Also, what code does it throw? Sounds like something fuel, air, CPU related...so that narrows it down to just about anything!!! It's almost like once the cars CPU has a chance to get some input to adjust the MAF, it messes up the Fuel-air mix.
Old 05-11-2006, 03:07 PM
it starts up everytime but sometimes it starts then jus dies. it's crazy it starts up like it's bout to run great then jus dies.
Old 05-16-2006, 10:54 PM
55624096 55624096 is offline
Had similiar MAF problem just after dealer replaced fuel rails. After changing sensor and lot of screwing around discovered that mechanic had placed the plastic tube in the intake hose, between air filter and MAF, improperly and it was restricting the flow of air. I removed the entire plastic tube and fixed the problem. No more check engine lite and MAF codes.
Old 05-25-2006, 09:43 PM
Triesd that and it didnt work my mechanic replace the pcm, maf sensor, oxygen sensor on cat, check for vac leaks, check grounds on all computers. And now im thinkin goingit to tha dealership. but if i use starting fluid it starts right up no prob
Old 05-26-2006, 05:50 PM
93pb 93pb is offline
Sounds like fuel pump to me. If it wont start on its own but if you spray starting fluid it will start and then dies once the fluid runs out it isn't getting the fuel.
Marc
Old 05-28-2006, 04:39 PM
Marc
Already had it checked and tha fuel pump and regulator is fine plus there were jus replaced a year ago
Old 06-11-2007, 02:33 PM
aurorafreek76 aurorafreek76 is offline
most important thing ive learned about my 97 aurora...is that big dealerships will screw your car up or misdiagnos it, whether on purpose or not thats debateable but the service techs at big dealerships are wanna be mechanics.....and the guy who has the two bay shack and lets you bring in your own parts do a way bettter job. of course i always am very friendly and tip them cuz i save 50% on 600-1000$ jobs. thats a lot!
Old 06-13-2007, 09:35 AM
BNaylor's Avatar
BNaylor BNaylor is offline
Sorry but please check the date and do not resurrect old threads. This thread has been closed.
POSTING IN CLOSED OR OUTDATED THREADS:
If a thread has been closed, there is probably a logical reason for it. If you feel that the reason(s) for closure of the original thread are unjustified or wish further clarification feel free to contact any member of the moderating team. However, do not start a new thread about another closed thread.
Please avoid posting or voting in outdated threads. It merely clutters up the message board and makes it more difficult for fellow members to sort through the vast amount of information contained on the boards. If you have new and important information to add regarding a past discussion, feel free to start a new thread and if need be, add a link to the original thread.
Timeslip 08/12/06
AF Community Guidelines
Closed Thread
