Old 05-08-2006, 09:39 PM
manx1962 manx1962 is offline
Bad smell
I have a 95 Blazer and there is something wrong if anyone would have any ideas that might help please post them....
First of all it seems to run fine little low on power when you are driving down the road but seems to be all there, but idles really ruff and kinda "slugish" hard starts sometimes and when it idles or after driving it after a while there seems to be a smell coming from it fron the exhaust like rotten eggs.. There is no check engine light on I put new plugs, wires, and had the EGR valve checked and he said it was clean.. Anyone have any ideas? I will try anything that I know or can do before I decide to take it into the shop and pay them to do it so any advice would be great thanks...
Old 05-08-2006, 10:27 PM
drdd's Avatar
drdd drdd is offline
Re: Bad smell
rotten egg smell (sulfur smell) is a sign of a clogged catalytic converter. Search 'rotten egg' on this forum.
your cat converter may have clogged due to excess fuel dumping from CPI/nut kit failure ... a common problem on 1995's ...
search 'CPI' and 'nutkut' ...
Old 05-09-2006, 02:48 AM
Re: Bad smell
I did a search on both Nut Kit and CPI and no matches were found...
Is it a do it your selfer or would you recommend haveing a shop do it? Where can I find info on this. Thanks again for your help.
Old 05-09-2006, 04:48 AM
muddog321 muddog321 is offline
AF -Advisor
Re: Bad smell
In the FAQ section.
http://www.automotiveforums.com/vbul...hlight=4.3+CPI
Old 05-09-2006, 07:55 AM
Southern Comfort's Avatar
Southern Comfort Southern Comfort is offline
Re: Bad smell
If you are smelling a rotten egg oder from you exhaust. It difinately is your cat stopped up, like drdd said. That will also cause a lack of power.
SC
Old 05-09-2006, 08:48 AM
drdd's Avatar
Re: Bad smell
you may have only searched the thread.
go to the main blazer page, log in, and click 'search forum', then type in your search
Old 05-10-2006, 01:47 AM
blazee's Avatar
blazee blazee is offline
Problem?
Re: Bad smell
CPI and Nit Kit are all three letter words. The search doesn't recognize three letter words anymore.
Old 05-10-2006, 04:17 AM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: Bad smell
The real problems is the cpi injector and the fuel line nut kit leaking.
The secondary failure from the leaking is the cat being clogged.
1995 Factory Blazer Service Manual for sale, PM if interested.
