Old 05-08-2006, 10:39 PM
jag_man653 jag_man653 is offline
Factors affecting FI pulse width, 95 PA Ultra
What factors does the 3.8L PCM look at in setting injector pulse width?
I know that it must use coolant temperature sensor, MAF sensor, and
engine RPM. Does it use manifold pressure? If so, where is the sensor?
TIA
Ed
Ed
'95 Park Ave Ultra
'76 Jaguar XJ-S
'06 Toyota Avalon XLS
Old 05-09-2006, 04:27 PM
maxwedge maxwedge is offline
A990 racer
Re: Factors affecting FI pulse width, 95 PA Ultra
tps, map if equipped, o'2 sensors also.
Old 05-09-2006, 08:06 PM
HotZ28's Avatar
HotZ28 HotZ28 is offline
AF Moderator Elite
If you have a MAF sensor, you will not have a MAP sensor. Basically the pulse width is controlled by CTS, TPS, MAF or MAP & 02. Engine rpm is not one of the factors.
