Go Back   Automotive Forums Car Chat > Nissan > Primera | G20 > Engine
Engine intakes, exhaust, turbos, nitrous.
Old 08-15-2001, 03:27 PM
RYANS RYANS is offline
Send a message via AIM to RYANS
cold air intake
i have a 1992 g20 i already put on a jwt pop charger. now i am intrested in putting on a cold air intake. i was wondering if the hot shot goes all the way to my manifold because it sits below the engine(i think it is the high port intake manifold). or does the hot shot connect at the maf. will you be able to use the aem air bypass valve with the hot shot intake. any help will be appreciated.
Old 08-15-2001, 05:46 PM
b-b00gie's Avatar
b-b00gie b-b00gie is offline
Banned
Send a message via AIM to b-b00gie
Not positive about the 92, you can make a call to HotShot and ask them. Would be the quickest way (and correct answer)
Pretty sure it goes to the intake mani. though.
You can fit the AEM BPV. You need the 3" one as this is the size of the HS piping. Mount it close to the MAF, do NOT put it near the filter...
Old 08-15-2001, 08:45 PM
P10DET's Avatar
P10DET P10DET is offline
And don't forget to mount it before the MAF - otherwise when the BPV opens, it will introduce unmetered air and thus your engine will run dangerously lean.
George Roffe
Houston, Texas USA
00 328i
91 SE-R (well modded)
84 944 SCCA ITS race car under construction
"I fear all we have done is to awaken a sleeping giant and filled him with a great resolve"
-- Admiral Yamamoto, December 7, 1941
