Go Back   Automotive Forums Car Chat > Saturn > SC/SL/SW
Old 05-08-2006, 10:26 PM
$ilv3rado's Avatar
$ilv3rado $ilv3rado is offline
Question 1994 Saturn SL2: Odometer failure?
Hey all,
I noticed a few days ago that my odometer and my mileage counter isn't rolling over anymore. I think it's only been like this for only a few days, but I thought this was an odd part to just stop working. All my other gauges such as speedometer and tachometer have been and are working fine (knock on wood). Does anyone have any suggestions to fixing this manually? Are Saturns of this year/model know for this type of problem? If this isn't one of those 'do it yourself' deals, then how much does one think it would cost?
Odometer stopped at: 179,729
Let me know if I left anything out that needs mentioning, please.
Your help and suggestions would be appreciated. Thanks.
1994 Saturn SL2 DOHC
Old 05-09-2006, 01:24 AM
sierrap615 sierrap615 is offline
Master Tech Wanna-be
Re: 1994 Saturn SL2: Odometer failure?
in fact, it is a common problem on early saturns, the cause is most commonly(99%+) traced to a broken odometer gear. the good new is you don't need to replace the entire cluster.
http://www.saturnfans.com/forums/sho...d.php?t=48348&
don't forget to manually update the mileage with a approxament figure.
Daily driver: 1995 Buick Regal Custom 3.8L 4T60-E 150K miles
Gone: 1994 Saturn SL2 1.9L MP3 168,666 miles
EPA 608 Universal Certification
EPA 609 Certification
Old 05-11-2006, 08:01 PM
$ilv3rado's Avatar
Thanks for the info, sierrap615. Again, odd part to 'go out', but makes sense. Although, buying both of those gears w/s&h actually costs a few $ more than buying a new cluster ( http://www.trademotion.com/partlocat...94&catalogid=1 ) O_o
Thanks for the help.
Old 05-12-2006, 02:54 AM
interesting, i imagine the price on trademotion is typo. it should be closer to the $450 price
Old 08-08-2006, 10:11 AM
Mbriggs Mbriggs is offline
$ilv3rado,
I have a 92 SL with the same problem. Did you ever get yours fixed? Was that a typo on the cluster price? Please let me know.
Thanks!
Old 08-14-2006, 11:22 PM
$ilv3rado's Avatar
Originally Posted by Mbriggs
$ilv3rado,
Thanks!
Hey Mbriggs,
I never did go through the trouble of replacing the gear in mine. I never really have the time to pull it all apart, and apparently you have to send the entire instrument cluster off to get one repaired/replaced around here. I've just left mine the way it is, and record the oil changes by the months so I'll have an estimated due date.
I'm not sure if that's a typo on the cluster price or not...if it is then they still haven't fixed it which is kind of odd. I suppose you could always contact the owners of the site about it though.
Hope that helps.
Old 09-08-2006, 11:56 PM
vlhgsd vlhgsd is offline
When I bought my SOHC, it had a cluster for a DOHC so speed was off. Bought the correct cluster off of ebay, had to replace some bulbs, but my 13 yr old son had the dash off and steering wheel dropped and done in about 30 minutes. Not hard at all. Here in Florida, I didn't worry about the odometer mileage since any car over 10 yrs old you can have mileage exempted which is what I did when I bought it.
