Go Back   Automotive Forums Car Chat > Fabrication & Tools > General Tools
General Tools Discussions about tools - there are thousands of various tools you can use to work on your car. Do you have the right one for the job?
Old 05-08-2006, 09:06 PM
bluevp00's Avatar
bluevp00 bluevp00 is offline
6 point vs. 12 point sockets
I was wondering what the advantages and disadvantages are with 6 point and 12 point sockets & wrenches. Or if one type is better in certian situations than the other (i.e. impact sockets are always 6 point).
In my tool set all of my 3/8 drive sockets are 12 point, and my 1/4 sockets are 6 point. I have the "starter" set, but I noticed that the "professional" sets contain both 12 pt. and 6 point for 3/8 and 1/2 sockets (all 1/4 sockets are 6 point).
Old 05-08-2006, 11:21 PM
'97ventureowner's Avatar
'97ventureowner '97ventureowner is offline
Re: 6 point vs. 12 point sockets
From my many years of experience and what my father told me a long time ago. a 6 pt socket is better to use over a 12 pt on most bolts because there is less chance of slippage and "rounding off" the bolt head. This is especially true of cheaper quality sockets . The 6 pt seems to grip better and allow you to use more force to loosen a bolt. I have also found a 12 pt. comes in handy with slightly rounded off bolt heads where a 6 pt doesn't seem to want to fit properly. I have been known to use a hammer to pound the 12 pt socket on the slightly rounded bolt before I attempt to get the bolt loose. A slightly smaller size socket works well with this attempt. I know what i just said kind of contradicts the earlier portion of this post, but there are certain circumstances where one type works better than the other. In my younger days, I was known to use 12 pt.SAE sockets to remove metric bolts, because I didn't have enough money at the time to have a proper metric socket set Seems many of the cars I owned back in the '80s from the '70s era had a mix of SAE and metric bolts on them which at the time was a pain in the ass when you didn't have the proper tools. Now I know better.
Thought for the Day… Alcohol does not make you fat - It makes you lean... against tables, chairs, floors, walls and ugly people.
If a prostitute here in America loses her job to a prostitute in India , is that considered "outwhoring"??-Jay Leno
" A Good Thing To Know"
Old 07-29-2010, 07:57 PM
rhandwor rhandwor is offline
You need 12 point for 12 point nuts and bolts. Occasionally a five point or 10 point are being used on some cars.
Old 10-27-2010, 10:47 AM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
You should use 6-point sockets when using a torque wrench, especially for larger bolts.
6-point is common for smaller sizes since there is simply not enough surface area contacting the bolt head to apply the needed torque without stripping the head if a 12-point socket were used.
But 12-points are common to provide a wider range of accessibility and ease of use...a lot faster to put a 12-point socket onto a bolt head.
Finally, use only sockets made for impact wrenches if at all possible...they are all 6-point. Regular 6-point sockets can be used if absolutely necessary but 12-points are not advisable at all.
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
Old 10-27-2010, 10:51 AM
Scrapper Scrapper is offline
AF Premium User
i agree 6 point all the way because they wont slip if you put it on rite size of bolt.
Old 10-27-2010, 02:37 PM
Poff Poff is offline
I prefer 6 points but there are 12 point bolts out there so you need both. I agree with '97ventureowner, there is less chance of sipping or rounding with a 6 point, especially on small sizes (below 1/2").
