Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 05-08-2006, 08:39 PM
copcarcrzy copcarcrzy is offline
Angry Coolant leak..
been a long week...
was told blown headgasket 2nd shop said no just an intake gasket.. had replaced as well as a sensor anlong the pass side block.. still leaking coolant and cant find it anywhere.. its closer to the rear on the pass front tire slightly inward will post pics tommorow. cant find it for the life of me
this is driving me nucking futs..
I thought it was leaking near the new sensor, but its dry as bone..
Old 05-08-2006, 10:28 PM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Re: Coolant leak..
My guess would be the intake itself. This is a fairly common occurance with the aluminum intakes on cars which the coolant hasn't been replaced at the required intervals.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 05-09-2006, 07:45 AM
Re: Coolant leak..
The intake gasket was just replaced. but they could have screwd it up.. Ill have to take it to the dealer and tell them im leaking coolant, And see what they say
Old 05-09-2006, 09:36 AM
Blue Bowtie's Avatar
Registered Offender
Re: Coolant leak..
Did you mention somewhere that this is an LT1/L99? You may also want to look at the coolant hoses to the throttle body and at the lower coolant passage/gaskets on the throttle body itself.
Old 05-09-2006, 10:15 AM
Re: Coolant leak..
this is an LT1.
will look for the location of the TBBP
