Go Back   Automotive Forums Car Chat > Nissan > 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX
Old 07-21-2002, 11:01 PM
HaZe HaZe is offline
Need some help wit a S15 JDM Silvia
I need some help with the S15 silvia. First, whats the max power you can get out of the stock internals on the Sr20det ? Second, how much does a S15 weigh ? Third, is the six speed transmission on the S15 weakly built ? How much HP will it hold before breaking and is the 6 speed geared for high speed like the Supra or the Skyline ? Thanx for all the help, if you can IM me my sn is [email protected], thanx
Old 11-08-2002, 10:40 PM
turbo2nr's Avatar
turbo2nr turbo2nr is offline
Send a message via AIM to turbo2nr
the s15 makes 250hp at da crank, i seen it make up 2 350hp wit stock iinternals, but after dat u need 2 reinforce da motor.
the tranny isnt dat weak, it 2 can hold up 2 400hp, da reason peeps say day weak caus in japan peeps use s-15 2 drift and driftin wears down ur tranny
if u road race or drag u ahould be fine
peeps say its weak to cause da busshing are made wit plastic like materials .
Old 11-30-2002, 11:13 PM
MadScientist's Avatar
MadScientist MadScientist is offline
Banned
Send a message via AIM to MadScientist
S15
Silvia S15
Engine/ Trany weights in at around 400lbs. I have see 400hp come out of a stock internal Blitz Silvia S15. There is actually 2 different 6 speed tranys for the S15. Stock S15 with a 6 speed is the odd Trany.
It sounds odd because it is a 5 speed with an added gear (dont ask how it was done, I dont know). The other is the S15 Spec-R, this trany is able to hold 400hp and ok for drift, but dont expect it to last under 400hp.
For parts for the SR20DET go to www.automotiveforums.com
Peace
Drew
