Re: service manuals
I was driving home from church and when I pulled out onto the highway my 1991 Honda Accord went dead. It would not crank and had to be towed home. I pulled a spark plug and the compression is still good. I loosened the main gas line and had gas there as well as on the spark plug I removed for the compression test. Can some one tell me what I could do next to get my Accord running again. I am really missing the great gas mileage.
Thanks, Billy |
Re: honda accord
I think you may be in the wrong section here,if you want replies best start new post......
How you check compression if it didnt crank? Anyhoo first thing to do is check for codes, second check lights to see if you have dead alternator/battery.Third, download the service manual(or maybe first). Last but not least try using the search at top of page for other similar posts. Good luck |
Re: 91 Accord wont crank
Moved.
96 3000gt vr4 -K&N FIPK -Proboost mbc -Cusco front + rear strut bars -Greddy type-s -ATR downpipe -no cats -15Gs, 3sx aluminum pulley, FMIC, SAFC, walboro pump, EVO 560ccs, and Meth Injection Kit all waiting to go in shortly. Your 1996 Mitsubishi 3000GT VR-4 is the 92nd out of the 315 that were made that year. Only 21 of which are exactly identical. |
Let's just get clear about "won't crank" and "won't fire"
"Won't crank" means when you turn the key, nothing (except maybe a click) happens. "Won't fire" means "it cranks, but the motor won't 'catch"" Which is it? (Although I can guess). |
Won' t fire. Battery good. I am really in need of this car. Please help
"Won't crank" means when you turn the key, nothing (except maybe a click) happens. "Won't fire" means "it cranks, but the motor won't 'catch"" Which is it? (Although I can guess).[/quote] |
Check the main realy under your dash board on the driver side. Its a black box with a bolt holding it on should say mistuba on the case. Also check the ECU fuse i have yet to have this problem yet but it located either in the fuse box, or under the dash passenger side. My friends civic did and it was the fuse.
Cant remember who posted it but if you see it give yourself credit Don't ever look at cars as just imports or domestics. Just because a car is made in a certain country doesn't mean that it is anything like another car from that country. An example of this is Mitsubishi reliability, just because they are Japanese doesn't mean that they are as reliable as a Honda or Toyota. Cardomain |
See if you got fire at plug if not probaly igniter which is inside distributor. If you have fire then spray starting fluid down the breather if it starts for a second then your problem is most likely the main relay.
