Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 05-08-2006, 06:38 PM
copcarcrzy copcarcrzy is offline
Coolant temp. sensor
the sensor located on the passange side of the block, above the stater has a broken wire, will this cause the fans to not work ??
Old 05-08-2006, 06:49 PM
TommySS TommySS is offline
Re: Coolant temp. sensor
Um, isn't that a knock sensor?
Old 05-08-2006, 06:59 PM
I dont think so.. the service manual shows its the coolant temp sensor as did the shop that just replaced it for me.. Ill double check to make sure
Old 05-08-2006, 07:28 PM
The coolant sensor for the 84 H-engine is in the T-stat housing. I don't have anything in the block by the starter except the (water jacket drain) plug.
To be fair, it could be a temp sensor, but on my 92 SBC C1500, there was a knock sensor where the plug would've gone.
Old 05-08-2006, 07:33 PM
this is a 96 lt1 the plug is located between two spark plugs..
Old 05-08-2006, 07:35 PM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Yes, that's the knock sensor. The coolant temperature sensor is generally located in the thermostat housing. Has a black and a yellow wire connecting to it.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 05-08-2006, 07:38 PM
Ohhhhhhhhh. Sorry. I don't have a manual for that engine.
Old 05-08-2006, 09:26 PM
silicon212's Avatar
Confoundingly Lucid
That would be the location of the temperature sending unit on any other small block. Is that what that is? The sending unit and temp sensor are two different things - the sending unit displays a temp on the car's coolant temp gauge while the temp sensor tells the computer how hot the engine is.
Old 05-09-2006, 06:43 AM
Now that you said "sending swith" I believe your right. should this have 1 or 2 wires connected to it
Old 05-09-2006, 08:12 AM
Blue Bowtie's Avatar
Registered Offender
If your vehicle has the heavy duty cooling package (RPO V08) it will be a little different. On the right (passenger) side of the block is a detonation sensor. Above that, in the right cylinder head (between the spark plugs) is the secondary cooling fan sensor. The left (driver side) head has the temperature sending unit for the dash instrument.
