Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 05-08-2006, 05:48 PM
redzero redzero is offline
Question lights on dash
I have a 96 rodeo with electrical problems. last year shortly after changing my alternator the brake, and four wheel drive engaged lights came on but they were dim. the car ran fine and everything on it was working until one summer day the lights brightened and my AC fan went out. when I took it to my mechanich he checked the alternator and said that it needed to be changed and we got a new alternator which didn't fix the problem. now my radio is not working. what is interesting is that sometimes the lights don't come on and things work for a short while until they stop working again. can anyone tell me if they have such a problem.
Old 05-08-2006, 08:28 PM
Gizmo42's Avatar
Gizmo42 Gizmo42 is offline
Re: lights on dash
Let me guess, aftermarket alternator.
Isuzus dont like them check http://www.automotiveforums.com/vbul...d.php?t=557933
--Dave
1999 Rodeo LS 3.2 4x4 5 Speed
32x11.50-15 BFG T/A KO
3" Lift - Rancho 9000x
Rear No-Slip Locker
Flowmaster 2.25" 50 Series
There is a very fine line between "hobby" and "mental illness." - Dave Barry
Old 05-08-2006, 09:45 PM
Ramblin Fever Ramblin Fever is offline
Re: lights on dash
Yep, the alternator's still the issue. Have to get OEM (Denso IIRC) or Bosch part# AL4439X
The Bosch is what I have on my '97 and it came with a 2yr warranty/roadside as well.
If the battery, brake light, etc are still on, even though they are dim, it's because your current alt isn't putting out enough. In regards to the A/C, stereo not working, same thing - these trucks are designed to power-down what's not necessary in order to save what juice is left to run right.
Eventually it will trigger funny transmission shifts (if it's an automatic) as well as make your headlights really dim.
Mine got so bad, as to literally only one headlight would come on, this was after it shut off the stereo, all climate controls, dash lights were real dim, gauges even got funny.
Don't be surprized if after you replace your alternator that your battery fails - it's very common for the weak alt's to suck the life out of the battery.
My 3 attempts at the aftermarket alt's killed 2 batteries.
1997 3.2L V6 Rodeo
32" Yoko's, 16x8 MB Wheels, 2" lift, Brushguard, KC Fog's, Loadwarrior Rack
On it's way to 185k strong
2004 3.4L Tacoma TRD off-road 4x4 Double cab
32" Yoko's, Westin Bull-bar, KC Fogs 60K miles
Old 05-09-2006, 10:10 AM
directory's Avatar
directory directory is offline
Re: lights on dash
has anyone tried getting their current alt rewound for more power?
or at least getting the new bosch alt rewoud to put out more power.
the placement of the alt in these trucks lack in the ability to allow bigger/ other aftermarket alts to be placed--without minor work with wiring/etc.
i'm basically looking to get about 100-120 amps out of the alt. to run lights/cb's, etc.--any ideas?
would placing the alt higher up on the engine work better to fit aftermarket alts? does it only come down to making it fit with brackets and keeping the belts in line?
what would i be up against? other than trying the fab up a bracket to hold the alt?
99 passport 3.2L v6 DOHC auto-trans 4x4 modified IFS 10 bolt front/ dana 44 4.10 rear
SKYWARN
we be clubbin'
--B
Old 05-09-2006, 10:47 AM
Canucklehead Canucklehead is offline
Send a message via MSN to Canucklehead
Re: lights on dash
Read this an let us know how it goes.
2000 VW New Beetle TDI
2007 Honda CR-V
Old 05-09-2006, 04:27 PM
directory's Avatar
Re: lights on dash
hmmm.. i don't think i want to get all that serious. plus, it doesn't say that it ups the amps--it just reaches it's full potential sooner at lower rpms
SKYWARN
we be clubbin'
--B
Old 05-09-2006, 06:17 PM
Re: lights on dash
Not an easy idea, directory - but, fwiw, I've been running regular lights, off-road driving lights, trailer lights, CB's, aftermarket CD player, a plug-in cooler for now almost 10yrs in my Rodeo. I am on the 3rd alternator though, in 155k miles.
1997 3.2L V6 Rodeo
Old 05-09-2006, 06:57 PM
directory's Avatar
Re: lights on dash
yeah, i have taken that into consideration. i don't know--i guess i'm just form the idea that overkill is better...i learn different soon i guess.
SKYWARN
we be clubbin'
--B
Old 10-03-2006, 01:59 PM
Re: lights on dash
Thank you all for your response. It turns out the problem was the alternator. I found this out after I took it to an automotive electronics specialist. Even though the alternator I had belongs on a 96 rodeo there were two alternators for that same year depending on which period of the year that the truck was manufactured in. I don't recall the model number of the alternator but if anyone is interested let me know and I will look it up.
