Go Back   Automotive Forums Car Chat > Mazda > B-Series/Bravo/Bounty/Drifter
B-Series/Bravo/Bounty/Drifter Bravo is the Australian vesion, Bounty the New Zealand version and Drifter the South African version.
Old 05-08-2006, 04:47 PM
BNS_maZda BNS_maZda is offline
do i need power steering?
i was told i could change some parts and get more HP but i cant have PS do i need it what do i have to do to get rid of it?
Old 05-09-2006, 10:16 AM
hocbj23 hocbj23 is offline
Re: do i need power steering?
I am not sure what parts you could add that would require losing your PS.Lots of 1st gen Mazda paikups did not come with PS so no you dont need it, but the truck is not very pleasant to drive without it.Bolt-ons for more power would be better ignition(Accel or equivalent),a better carb (try a Webber 34), a B2600 radiator with and electric fan (lose your old fan and clutch),Flowmaster or equivalent free flow muffler.BJ
Old 05-09-2006, 11:48 AM
no one of the things in here there is a web site mazdatruckin.com tells me i can put a crank pully from a ford probe but i cant have PS to do it
Old 05-09-2006, 11:54 AM
and with the rad from the B2600 do i have to change the whole rad and fan and how does i wire up?
Old 05-09-2006, 12:57 PM
Rad is direct bolt up.You will lose the weight and inertia of the stock fan and fan clutch.You will need a heat sensor to turn the fan on which is temp sensitive . Possibilities are endless, probe fastened to rear of rad, tee off the temp sending unit, or the fan mfg. probably has all sorts of solutions , that is an easy fix. BJ
Old 05-09-2006, 01:01 PM
Bump. Sorry. The replacement fan is electric and not driven off a belt, and will need to be bolted to either the front of your radiator (if you have no A/C) or the rear of rad if you do.It will need a power source.The 2600 rad is a complete unit with more cooling capacity.BJ
