93 blazer s10 power window trouble
I had a short in the wiring to the ING/GUA fuse and the process of fixing it I had to pull the dash out. I fixed the short witch had nothing to do with the the windows, I put the dash back in and put everthing back together. Now the power windows do not work, I checked the fuse(it's good). Could I have forgot to plug something together behind the dash. Is there a connector behind the dash. Any help would be great, Thank You.
Re: 93 blazer s10 power window trouble
You've probably disconected something by mistake.
However since it's a pain in the butt to pull the dash out and pretty easy to pull the switch off the drivers door panel I sugest that you pull the switches and see if you have power there. If you don't you'll have to chase the wire down, but if you do it's easy to find the problem |
