Go Back   Automotive Forums Car Chat > Mitsubishi > Montero/Shogun/Pajero
Old 05-08-2006, 02:48 PM
redban redban is offline
Cool glow plug problem
i have a 2.5 diesel pajero 1992
the glow plug warning light has stopped working and there is no power to the relays with the ignition on
is this a fuse protected circuit if so where is it located.
or any other ideas on this problem
Old 09-07-2006, 05:53 AM
davidvh2 davidvh2 is offline
Re: glow plug problem
My 1993 model 2.5 diesel is literally en-route to me now. I understand that on this model there is no glowplug light. Instead, one has to listen for two clicks before attempting to start. The clicks indicate that the plugs have heated up. No clicks, no heated plugs & one has a problem to investigate. Could be a plug or the relay control at fault so check voltage gettting to plugs first.
Rgds. David
Old 10-09-2007, 05:14 AM
CCGrayson CCGrayson is offline
Send a message via Yahoo to CCGrayson
It is fuse protected and your fuses can be found in 2 places. In the drivers side footwell, right under the plastics on the right hand side and in the engine bay too. It is simply a process of elimination.
For the footwell fuses, get a torch, you'll need it.
