Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 05-08-2006, 01:01 PM
ez1286's Avatar
ez1286 ez1286 is offline
Send a message via AIM to ez1286
Noooooooo!!!!!!!!!!!!!!!!
Well i took my oil pan off today ad found about 50 small aluminum flakes in there. They are pretty big flakes a lot larger then i would expect (about 1/4'' in diameter) I'm going to take all the main and rod caps off. Do you guys think it's a spun bearing?
95 GSX:FMIC, 6-bolt, evo 3 16g, 2600 act clutch, 1g bov (crushed), and a 3" turbo back exhaust, dsmlink, dks 272 cams, wideband 02, Coming soon 2.3L Stroker, 1mm oversized valves, crower sprigs. 91 TSI AWD auto, gm 3.5 maf, maft, fmic, emanage, profec e-01, 3" turbo bk exhaust +more little stuff.
http://www.ratemydsm.com/member/ez1286/?member=ez1286
Old 05-08-2006, 01:51 PM
Killa's Avatar
Killa Killa is offline
Re: Noooooooo!!!!!!!!!!!!!!!!
dam. Hope every thing work out ok man.
GM FOR LIFE !!
NEW 1997 Camaro z28 6 speed
illa never going back to import , but killa alway be nice to any DSM he saw
looking for 2002 Trans Am LSX
UPGRATE 2010 !! 97 Camaro Z28
95 camaro lt1
1992 Pontiac Firebird v6 auto -sold -
Pony 1998 Mustang GT 4.6L Manual. Black
1995 Eagle Talon TSI AWD Turbo manual R.I.P
1994 Mitsubishi Eclipse Manual gray -Sold
1997 Mitsubishi Eclipse RS Auto White - Sold
Old 05-08-2006, 03:09 PM
-Josh-'s Avatar
-Josh- -Josh- is offline
Automotive love doctor
Send a message via AIM to -Josh-
You had flakes that big with no knocking noise or anything? I find that hard to believe there could be that much damage and no noise.
Self improvement is masturbation
AF User Guidelines
What is a mippie? - click
Old 05-08-2006, 04:10 PM
ez1286's Avatar
well the car didn't run after it happened. I almost have the head off. I'm thinking it's time to rebuild the engine, well at least i'll have a stroker a lot sooner than planned.
Old 05-08-2006, 07:43 PM
MexRocket's Avatar
MexRocket MexRocket is offline
HE gone done broke it.
STATUS: Near completion for the Engine
PROJECT BEST 1G IN IL:70% Done
MODS: C2 boost,mbc,B16GEGTurbo,12x28x3x3 FMIC,Ported2gmani,k&n.
Being bought in two weeks: Dsmlink,880's,3"exhaust,piping,suspension,axel,dri lled and slotted brakes.
Old 05-08-2006, 09:54 PM
ez1286's Avatar
I shall stroke myself...uh... i mean my engine. I talked to the parents and they can lend me some cash to buy the stroker kit. I'm thining of getting the ffwdconnection.com kit but i'm still looking.
Old 05-08-2006, 10:55 PM
AbsoluteGTR's Avatar
AbsoluteGTR AbsoluteGTR is offline
Send a message via AIM to AbsoluteGTR Send a message via MSN to AbsoluteGTR
Sorry ya'll this might be a newbie question, but what exactly is a stroker engine? What benefits does it have, and what exactly is it?
If someone has a link full of stroker info that would be awesome, THANKS!
Old 05-08-2006, 11:28 PM
nova1313's Avatar
nova1313 nova1313 is offline
it's essentially a longer stroke on each rod in the engine. So there is more distance for it to travel = more room for fuel and air.
Thats a short definition. The 4g64 I guess could be considered a stroked 4g63 or is that an incorrect statement?
08 Kawasaki Ninja 250R - Plasma Candy Blue
07 Toyota Rav4 - Ltd Ed. 6 Cyl AWD
97 Mitsu Eclipse Spyder GS-T 5 Speed
Old 05-08-2006, 11:30 PM
ez1286's Avatar
basically a stroker makes the piston go down farther in the bock, this creates more volume for combustion. The piston wrist pin is set higher in the piston doesn't rocket through the head.
Old 05-09-2006, 12:55 AM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
A stroker is exactly what these guys are saying, it's a longer "stroke" for the 4-cycle engine in each of it's cycles (intake, compression, power, exhaust). With a longer stroke the cylinder now has more volume for more air which in turn equals more power. On our turbo cars, a stroker spools a larger turbo quite a bit easier than a regular 2.0, and they can produce more power too. The only disadvantage of it is that you can't rev to way way high numbers. I know Kevin said he revved his stroker to 8500, but you could rev a destroked engine to upwards 10k if you really wanted to. IMO, the advantages greatly outweigh the disadvantages. And there you have it, strokers in a nutshell.
95 Talon TSI AWD
97 Eclipse GST
Old 05-09-2006, 10:03 PM
vanilla gorilla's Avatar
vanilla gorilla vanilla gorilla is offline
Thats a correct statement
Caleb
vanilla gorilla
'99 Spyder 2.4 5-speed - Red/black,14b,slow
'96 Eclipse GST 5-speed - Paint
www.myspace.com/ballsoutperformance
Old 05-11-2006, 01:19 PM
kjewer1 kjewer1 is offline
AF - Advisor
Yup, the 4g64 is a little bigger on the bore, and 6mm taller in the deck, but is essentially the same block. In fact the 64 block and 63 crank come out to the 2.1 destroker.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 05-11-2006, 01:46 PM
GSXracerGuy GSXracerGuy is offline
Send a message via AIM to GSXracerGuy
Why do 97-99's look so much damn better than my stupid 95 GSX? It makes me want to throw mine away because it looks retarded to those. They are rounder or something..I know the front is lower with a diff stock bumper and the healights are different etc...(I am familiar with that 97-99 conversion stuff)..
Yea so that had nothin to do with the post. sorry
1995 GSX M/t 87k[IMG][IMG]
Gotta lotta work to do.
[IMG][/IMG]
Old 05-11-2006, 03:06 PM
Killa's Avatar
man dont hate your car cause the body style, i help my friend doing 97-99 convertion, in less then an hours. I have a 97 eclipse in yunk yard that I properly doing convert if I pick up a 95-96 model. Put if you really need that bad I let it go cheap.
GM FOR LIFE !!
95 camaro lt1
Old 05-11-2006, 06:26 PM
How cheap?
[IMG][/IMG]
