Old 05-08-2006, 12:12 AM
JunkTitleGolf's Avatar
JunkTitleGolf JunkTitleGolf is offline
DVC heats more than SVC?
I was at circuit city and this guy told me that a dvc sub wouldn't be good for my amp because it will over heat it. Is that true. I've never heard anything like that. Or was he feeding me a line of poo just to get me to special order a SVC sub that can handle 500 rms?
Old 05-08-2006, 12:19 AM
sr20de4evr's Avatar
sr20de4evr sr20de4evr is offline
Re: DVC heats more than SVC?
he's mentally retarded...or you just misunderstood him
'01 Black Sentra SE
Weapon-R intake, HS header, HKS catback, ES motor mounts, B&M short shifter, Tein coilovers
Alpine 9835, Adire Koda 6.1, Adire Brahma 15, Arc 2100cxl, Linear Power 2.2hv, Cadence ZRS-8
'05 Silver WRX STi
Injen SES Downpipe, HKS Carbon-Ti catback, Cobb Stage 2 Tune, TiC Super Shifter, TiC Klunk Killer, Tein springs, Nitto NT555R Drag Radials
Old 05-08-2006, 12:42 AM
NAVY IC's Avatar
NAVY IC NAVY IC is offline
It sounds like some important parts of the conversation are being left out. Was he saying that in response to you wanting to go with a particular wiring setup for some particular pieces of equipment...?? You would really have to mis-match your set-up in regards to other variables more so than the DVC/SVC issue.
Old 05-08-2006, 09:39 AM
No I went in and they did that whole rush you and ask you if you need help to try to make comission thing. And I told him I need 2 subs that can handle 500 rms and he asked me what amp it was then told me that he doesn't carry any SVC that could handle that and a DVC would overheat my amp.
Old 05-08-2006, 10:57 AM
pre98zetec's Avatar
pre98zetec pre98zetec is offline
Send a message via AIM to pre98zetec Send a message via MSN to pre98zetec Send a message via Yahoo to pre98zetec
circuit city isnt commission, AFAIK.
besides, why would you even ask for help just go look around.
-Josh-
96' Integra GSR / ITR cams/valvetrain. Skunk2 IM, Greddy evo2, AEM CAI, RMF Header, Megan testpipe, Hasport mounts, Eibach coilovers, Beaks tie bar, Megan H brace, Rota Attacks, F/R strut bar, Kirk 6 point cage, Bride Cugas, Takata 4 Point, ITR Steering wheel
98' SVT Contour, 3L Port-Matched swap with SVT cams/full bolt ons; 224fwhp.
01' Chevy Blazer, DD.
Old 05-08-2006, 12:53 PM
CBFryman's Avatar
CBFryman CBFryman is offline
Banned
Send a message via AIM to CBFryman Send a message via Yahoo to CBFryman
amp sees load. That is it. So if it is seeing a load which it is stable at, it will be happy assumieng you arent over driving the amp wit hthe volume knob.
so im with SR20
what you may have misunderstood what he was say is as follows.
Say you where deviding between a 4ohm SVC driver and a Dual 4ohm Driver. Your amps isonly 4ohm stable. Buying the D4 will do one of three things. 1.) wire at 8ohm cuting your power ouput in half assumeing your amp is not regulated. 2.) wire to 2ohm and give the amp too low of a load resulting in protection or overheating or clipping or a mixture of any of the three. 3.) only power one coil cutting your thermal handleing in half along with efficency and Bl caysing alot of other parameters to change drastically.
