Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 05-07-2006, 09:13 PM
matt50317 matt50317 is offline
Transmisson problem
I have a 1991 Eagel Talon Tsi automatic, new engine with a 16g small turbo, and tubular manifold, pacesetter cat back exhaust K&N filters. when i get on the interstate the car gets going but when it trys to shift up, it over revs as if it wants to down shift instead, then i have to let of the gas and let the rpms go back down and then it shifts into gear, Does any body know what the problem could be?
Old 05-08-2006, 12:54 AM
L-Spec's Avatar
L-Spec L-Spec is offline
Send a message via MSN to L-Spec
Re: Transmisson problem
Over rev as in it actually redlines? Possibly because your transmission is worn down and it wont engage properly until you let off the gas and give it time to engage. My buddie had a probalem with his Talon automatic.. ocassionally, his transmission would stay in its 1st gear and refuse to shift until he put into neutral and let the transmission catch up. Do you have any more info? Does this only happen when you give it WOT or something?
1992 Ẽfini RX-7 FD3S
Old 05-08-2006, 01:00 AM
no i don't let the car reach the redline but it gets very close to it, and what do you mean by WOT? but i really don't have any more informatin then what i posted, i was told by a friend that it could be a sensor but what sensor is it if it is a sensor?
Old 05-08-2006, 01:24 AM
Killa's Avatar
Killa Killa is offline
wide open throat
GM FOR LIFE !!
NEW 1997 Camaro z28 6 speed
illa never going back to import , but killa alway be nice to any DSM he saw
looking for 2002 Trans Am LSX
UPGRATE 2010 !! 97 Camaro Z28
95 camaro lt1
1992 Pontiac Firebird v6 auto -sold -
Pony 1998 Mustang GT 4.6L Manual. Black
1995 Eagle Talon TSI AWD Turbo manual R.I.P
1994 Mitsubishi Eclipse Manual gray -Sold
1997 Mitsubishi Eclipse RS Auto White - Sold
Old 05-08-2006, 01:25 AM
L-Spec's Avatar
WOT = Wide Open Throttle aka flooring the gas pedal. How long have you had your car? If I were you, I'd keep it floored and see if it even goes to redline and shifts or not. Autos redline at 6500 rpms, correct? Let it go to 6600-6700 rpm. I believe it should shift at around 6100ish rpm if you keep the gas pedal down. Entering a higher speeds, the automatics do tend to rev quickly (experience in the 420A not 4G63).
So, just keep it floored until it actually does hit redline. It will shift. I see no reason why not, especially if it drives fine during regular driving scenerios. But again, how long have you had your car for?
Old 05-08-2006, 01:59 AM
l_eclipse_l's Avatar
l_eclipse_l l_eclipse_l is offline
Originally Posted by Killer7
wide open throat
'92 3000gt SL
Zoom Stage 1 Clutch
Originally Posted by kjewer1
I disagree. Better is better. Bigger is just bigger.
I just made that up, and I like it.
Old 05-08-2006, 02:11 AM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
When was the last time a filter and fluid change was done? Alot of times people will find that a transmission tune-up will solve alot of small shifting problems.
wide open throat
WOT= heavy breathing and catching bugs with "throat open wide"
95 Talon TSI AWD
97 Eclipse GST
Old 05-20-2006, 10:38 PM
I just put a new engine in the car so every filter in the engine bay as been replaced IE: transmission, gas, oil.
Old 05-20-2006, 10:40 PM
i replaced all the filters when replaced the old engine so every filter in the engine bay is new
Old 05-20-2006, 10:43 PM
Killa's Avatar
Originally Posted by l_eclipse_l
my bad ( i hate my english )
GM FOR LIFE !!
95 camaro lt1
