Go Back   Automotive Forums Car Chat > Dodge > Neon | Plymouth Neon > 1st Gen 95-99
Old 05-07-2006, 08:33 PM
72 rs's Avatar
72 rs 72 rs is offline
Question water looks muddy
i just aquired a 96 neon (2 liter- 5 speed- 120,000 miles) for FREE; of course it has its problems. the one issue that i need help with is the cooling system....... it seems oil keeps finding its way into the coolant. Before i was given the car i flushed the cooling system on it for a friend, and the coolant looked grey and was the consitenty fo runny mud. i flushed the system until nothing but clean water ran out, added water and antifreeze. she drove the car for about 2 1/2 months and noticed it was running a bit warmer than normal after a while . i checked the collant again, and again it looked muddy again. other than this the car runs like a champ- No water in the oil, no bubbling in the coolant so i dont think it the head gasket, but i could be wrong. ANY HELP WOULD BE GREAT..
87 chevy silvy
91 transam 700r4 and torque convt.
new comp.
hypertech chip
accell ign. cont. modual
dual electric fans
94 lt1 long tube headers
custom exhaust
flowmaster 40 series muff.
3-4 suspension drop
helix tbi spacer
k&n airfilter
custom built cold air intake
Old 05-08-2006, 08:44 AM
das2123 das2123 is offline
Tuning Neons since '97
Send a message via AIM to das2123 Send a message via Yahoo to das2123
Re: water looks muddy
More than likely it's the headgasket. Oil in the coolant is a good indicator. The radiator could be bad and just rusting out while your driving, but I would think it's the HG. It's a pretty simple fix.
Old 05-08-2006, 10:37 PM
sheetmagnet2 sheetmagnet2 is offline
Send a message via Yahoo to sheetmagnet2
Well if it is the oil, dump it out and let it sit... if you see oil definitely seperating, then as das said, it's a head gasket. But, it sounds to me like it's a good chance that the radiator is just corroded like most radiators do after a few years... try flushing it out again first, and when you add coolant and water, add a bottle of Prestone sealant and 100,000-mile radiator conditioner to it... it should seal up all the pits and slow down the radiator corrosion. The overheating could just be a bad thermostat... cheap replacement part.
