Go Back   Automotive Forums Car Chat > Toyota > Supra > General
General Discuss anything having to do with Toyota Supra here.
Old 05-07-2006, 07:06 PM
supraturbo87 supraturbo87 is offline
Send a message via AIM to supraturbo87
ecu wire harness question
I have an 87 supra turbo, but I had to get a different engine, the one i was sent had round engine mounts on it so its an 89+ and I was wondering if the 87 ecu will match an 89 wireharness. If that won't work would an 87 wire harness be compatible with an 89 engine. Thanks, Justin.
Old 05-07-2006, 11:41 PM
TcmaBoy's Avatar
TcmaBoy TcmaBoy is offline
AF - Advisor
Re: ecu wire harness question
It should be compatible.
Don't you SAS me boy.
Please wheel responsibly.
http://www.treadlightly.org/
Old 05-08-2006, 12:19 AM
projectsupramk3's Avatar
projectsupramk3 projectsupramk3 is offline
Send a message via AIM to projectsupramk3
You can not mix and match yellow plug and grey plug harnesses, the new harness will not work with the old ECU. Just use your old engine harness and some sensors on the new engine, everything will work fine.
Old 05-08-2006, 02:59 PM
my old harness is brittle and falling apart, so I was going to order a new one, What year should I get? Thanks.
