Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 05-07-2006, 06:56 PM
mtcs's Avatar
mtcs mtcs is offline
Send a message via AIM to mtcs Send a message via MSN to mtcs
Garrett GT35R info please!!!!
What do you guys know about the Garrett GT35r's spool up rate....at what RPM range does it begin to spool?
Also, anyone have this setup? or know any good or negative things about it?
Thanks
1996 ECLIPSE GST
2.3 Storker, 6 bolt, XACT flywheel, ACT Clutch, B&M shifter, DC SPORT Carbon steel strut tower bars, EVO2 exhaust, 1000cc injectors,Aeromoive rail, MBC boost controller, PTE 6152SP, SBR exhaust manifold, TIAL BOV, SBR FMIC, TEIN SS, Walbro fuel pump, AEM EMS, AEM UEGO, FP turbo intake, Aeromotive FPR, Magnus intake, 62mm throttlebody, Stoptech big brake kit, brembo rear slotted discs, Stage 2 Shep transmission (quafe), sparco fighter seats, sparco harnesses
Old 05-07-2006, 07:23 PM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
Re: Garrett GT35R info please!!!!
On your FWD, you would never hook up. You'd need slicks like 10 feet wide .
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
Old 05-07-2006, 07:47 PM
mtcs's Avatar
I want to have it at 400-500...then later on do more mods and geti t up higher...
LSD should be mod with htis turbo huh
1996 ECLIPSE GST
Old 05-07-2006, 07:59 PM
Thor06's Avatar
Jizzed In My Pants
Yeah. Actually, I would go LSD for any FWD. If you get some wide rims and decent slicks and the LSD you should be ok.
Old 05-07-2006, 08:05 PM
Black99GST's Avatar
Black99GST Black99GST is offline
Send a message via AIM to Black99GST
umm... IIRC, spooling begins @ 4500? ish, full boost by 5k, fuel cut @ 7200, whats the point? get a 60 trim for your power goal... pleanty of play room...
Old 05-07-2006, 11:05 PM
kjewer1 kjewer1 is offline
AF - Advisor
4400-4500 rpm on a 2 liter, 37-3800 on a stroker.
I don't like anything above a 50 trim for the older garret t04 stuff. The 54, 57, and 60 trim turbos never impressed me. The 60-1 is a poor fit too but does well usually. For the newer GT stuff something like a 3076 (GT12) will do very well for most poeple with a limit of 55 lbs/min. Problem is there is nothing that fits in between that and the 65 lb/min 35R (GT14). There is a BB version with what appears to be a 60-1 wheel, which should come in around 60-62 lbs, but only a small spool advantage over the more appropriate 14 wheel.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 05-08-2006, 09:49 AM
TheRomer TheRomer is offline
I have a brand new GT3076R (GT12) BB turbo for sale if you want it...
Chris Winchell
95 GSX 12.5 ET with a 1.9 60' at 115 mph
Actually have traction this year
90 TSI <Project Acer>
2.0L, 2400 lbs AWD, t-67 goodness
