Old 05-07-2006, 03:52 PM
vicscar vicscar is offline
loud noise coming from rear on a 93 Ford Taurus
after 20 minutes of driving we start to hear a humming sound coming from the rear of the car. sounds like rear wheel bearings so i removed the tires, to find no noticeable signs on either side, no movement or noise. bearing cap says "no lube requried" do not remove. this noise started months ago but was very seldom but now after 20 mins of driving almost constant noise, if brake is applied noise goes away. HELP how can i tell if it's the bearings and how to do?
Old 05-07-2006, 09:17 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Re: 93 Ford Taurus
With the rear of the car raised so the wheels are not touching the ground and the car safely supported on jackstands, remove the rear wheels. Next, remove the rear brake drums (assuming you have drum brakes. Do not inhale at the exact moment you remove the drums as there is likely to be a lot of brake dust in the drum. Inspect the condition of the brake drum and brake shoes, as well as the brake springs, etc. Check for signs of extreme heat on the braking surfaces (usually indicated by a discoloration). Also, make sure there is no grease-like substance in there. That might indicate a leaking wheel cylinder.
With the drum still removed from the hub, rotate the hub by hand and pay attention for any roughness in rotation. This might indicate worn wheel bearings.
If your Taurus has rear disc brakes, then you will want to remove the rear pads, caliper mounting braket, and rotor. Inspect everything along the way. Rotate the hub in the same way checking for roughness.
-Rod
Old 05-07-2006, 10:44 PM
brokenantimatter brokenantimatter is offline
Re: 93 Ford Taurus
When was your last break change and did you get the brakes resurfaced when you had the breaks done?
