Go Back   Automotive Forums Car Chat > Chevrolet > Venture
Old 05-07-2006, 01:00 PM
planet_o planet_o is offline
bank 1 oxygen sensor
hello all... i recently had a mechanic change the bank 1 oxgen sensor (the one before the convertor)....but the problem now is the service engine soon light keeps coming back on for the same problem....he erased it and i erased from the code.....i dont know what to do!!......p.s...i keep erasing it with a OBD2 code reader machine.......thank you!!!!!
Old 05-08-2006, 12:18 PM
cdru's Avatar
cdru cdru is offline
Re: bank 1 oxygen sensor
What code is he getting? It's possible that it's not plugged in, was a faulty sensor, has gone bad like the former, wire damage, etc.
Vinyl adds horsepower, right?
Old 05-08-2006, 04:26 PM
the code were getting is (171)....
Old 05-08-2006, 08:45 PM
gmtech79's Avatar
gmtech79 gmtech79 is offline
That is a DTC for fuel trim lean. The HO2S is probably doing it's job, you need to find what is causing the HO2S to stay lean. You probably have a vacuum leak somewhere or low/restricted fuel pressure. You're not running E-85 are you? I promise you that E-85 will set lean codes with that vehicle or any other vehicle not designed for E-85.
ASE Master
ASE Advanced Engine performance
GM World Class Technician
1978 Pontiac Trans Am
1984 Monte Carlo SS
1991 GMC C1500
2002 Pontiac Grand Prix
Old 05-11-2006, 07:41 PM
what is e-85??
Old 05-11-2006, 09:03 PM
gmtech79's Avatar
85% ethanol fuel
If you read some other posts about ethanol you will see that you need a richer air/fuel ratio with ethanol
ASE Master
1984 Monte Carlo SS
1991 GMC C1500
