Old 05-07-2006, 12:49 PM
mechgo1977 mechgo1977 is offline
Question Bad Coil again / 85 Chevy 4.3L
I replaced the coil about every 5 months, it just decides to not spark anymore. And I also replace the cap, rotor and plugs if they need it.
This one has no computer and the distributor has had the ignition modual changed out to a 4 pin.
Any ideas why the coil keeps going??
The local autoparts store said I had an electrical problem (no kidding).
Mech
Old 08-19-2006, 09:45 PM
Sandho Sandho is offline
Re: Bad Coil again / 85 Chevy 4.3L
Check the engine to frame ground. A bad ground will cause that.
Old 08-20-2006, 09:46 AM
Bob B Bob B is offline
Hi,
There is a little jumper in the cap that is the ground for the coil. It is very easy to lose it while the coil is being replaced. It can run but sometimes poorly. Then fail.
Look at the plug in the cap for the wires and see that there is a jumper in the center slot.
Bob B
