1997 Town Car Turn Signal/Flasher Question
Hello All:
I have again borrowed my father's TC and discovered yet another anomoly. When using the right turn signal, occasionally the flasher will click at twice the speed as normal. When this happens, both the right front turn signal bulb and the right dashboard arrow will fail to illuminate. Play with the stalk a little and normal operation will return. The same thing occurs when operating the emergency flashers. I believe we have a turn signal/flasher switch block in the steering column that is starting to fail. Is there anything else I should look at first before attempting to replace the switch block? Also, how difficult is it to remove the steering wheel and replace this switch myself. Any input would be appreciated.
"This car may be old, but it will still climb Kirker Pass at 110!" 1962 Chrysler 300 2-door hardtop/1964 Chrysler 300-K convertible/1964 Chrysler Newport 4-door sedan/1964 Chrysler 300-K hardtop with Firepower 390/2x1964 Chrysler 300-K hardtop/1964 Chrysler 300 convertible/1964 Chrysler "Silver 300-K" with factory 4-speed/1964 Chrysler New Yorker Salon/1980 Dodge D-50 Sport/1986 Lincoln Continental/1989 Honda Accord DX/1989 Lincoln Mark VII BB/1991 Dodge Shadow ES convertible |
Re: 1997 Town Car Turn Signal/Flasher Question
[quote=KManiac]Hello All:
I have again borrowed my father's TC and discovered yet another anomoly. When using the right turn signal, occasionally the flasher will click at twice the speed as normal. When this happens, both the right front turn signal bulb and the right dashboard arrow will fail to illuminate. Play with the stalk a little and normal operation will return. The same thing occurs when operating the emergency flashers. I believe we have a turn signal/flasher switch block in the steering column that is starting to fail. Is there anything else I should look at first before attempting to replace the switch block? Also, how difficult is it to remove the steering wheel and replace this switch myself. Any input would be appreciated.[/QUwhen it flashes twice the speed means that 1 of your bulb is not working( in the bulb has 2 links , 1 is not working, meaning u have to change the bulb even if 1 link is still working. |
And its going to be a pain, i would think, to get under there and fix it. If you want some town-car specific forums try http://www.lincolnsonline.com/ |
[quote=sunny16888]
my 95 town car sometimes does the EXACT same thing. however, with the right turn signal, if i like hit the stalk too hard thats when the arrow doesnt blink and the turn signal in the front doesn't either. but when i push it down gently it does not do this. now with the flashers, all i do is wiggle the flasher button a little and then the right flasher starts to work again. so i would agree that it is something in the steering column but with my car it is just a nuissance that happens only once every blue moon
Sean |
Its nice to know that we are not the only ones out there with the annoying problem. I guess we will just live with it until it fails completely. My father is considering having the switch replaced by the Lincoln Dealer. If he does so, so be it.
