Go Back   Automotive Forums Car Chat > Honda > Del Sol
Old 05-06-2006, 09:55 PM
cyruslam cyruslam is offline
Problems....
The Boot stucked when i pressed the button to open the top. Then i cant close the boot with the key any more. have put the car to an auto electrician for two weeks, still dont know what happened. Have checked the gear of the tiler, they are all good.
Does anyone know if i close the boot manually. Will everything back to normal?? e.g no beep noise, the boot can open/Close with the key, the car can drive etc.
The Cable which use to close the boot manually is broken, i will have to change it before i can close it.
Old 05-07-2006, 09:10 AM
94SolGrl's Avatar
94SolGrl 94SolGrl is offline
Honda GODDESS/Global Mod
Send a message via AIM to 94SolGrl Send a message via MSN to 94SolGrl
Re: Problems....
The boot getting stuck is a very VERY common problem with the transtop mechanism. All of the gears inside the mechanism are made from plastic, which is weak. You may not be able to see it, but I am almost certain that one of the gears is broken or not working correctly. There are a few companies that make metal replacement gears for the transtop which are much better. Search this forum for a member named "mariejader". That member owns a shop in Scotland that specializes in TransTop repair. They might be able to help you out with your problem.
Also, it is my understanding that if the TransTop gets stuck and you manually crank it down, once you press the button again, it will only get stuck again.
~*Emily*~
1995 Nissan 240SX - S15 whore
HOW TO POST PICS!
Old 05-07-2006, 03:44 PM
Re: Problems....
Ok, so does that mean if i close the trunk manually, and i dont press the button, the car can be drive without engine cut, and the trunk can be open/close with the key(it auto lift up/down with the key before it jam)?
Thx a lot for ur help
Old 05-07-2006, 06:48 PM
94SolGrl's Avatar
Re: Problems....
I believe what you said is correct.. if you get it cranked all the way down and closed then you don't run into the engine cut problem.
US del Sols didn't come with the transtop, so my knowledge of them is limited. Sorry.
~*Emily*~
HOW TO POST PICS!
