Old 05-06-2006, 08:57 PM
dressler dressler is offline
Exclamation '02 Trailblazer Problems!
‘02 Trailblazer 4.2 L after motor swap, loses Serial 2 data communication with scan tool when ignition is turned to run position. Vehicle no start - no click. Ignition switch has been replaced. DLC tested good. Splice pack SP205 checks good with no loss of communication. Serial 2 voltage jumps very high when key is turned to the run position. All grounds checked and clean. Any ideas?
Old 05-07-2006, 06:41 AM
rodeo02 rodeo02 is offline
Re: '02 Trailblazer Problems!
Almost sounds like something with the passlock system is holding you out. Not sure how that would tie into the engine swap though?!?
Joel
2016 Subaru Forester 2.5i base CVT
2016 Nissan Quest SV
