Go Back   Automotive Forums Car Chat > GMC > Jimmy
Old 05-06-2006, 07:51 PM
majk majk is offline
Exclamation Multifuction Svitch For Turn Signal
I have problem with turn signal
I hear clicking oldetime in JIMMY 1998
Is the problem multifuction svitch
Where is the svitch in the JIMY
Where i mast loking for found this svitch
Thanks
Old 05-11-2006, 07:36 AM
rlith's Avatar
rlith rlith is offline
Send a message via AIM to rlith Send a message via MSN to rlith
Re: Multifuction Svitch For Turn Signal
Thanks
Why do you substitute V for W??
Anyway, the sWitch is in the column and yes, it's most likely bad. You can try replacing just the hazard sWitch, that sometimes works.
Old 06-22-2006, 12:52 PM
RudeRam RudeRam is offline
Send a message via AIM to RudeRam
Do you have the instructions to replace the hazard switch? I have the same issue with my 98
Thanks
Rick
Old 06-22-2006, 06:13 PM
Thumbs down Re: Multifuction Svitch For Turn Signal
No
Its no problem with hazard switch
Its problem with multifuction switch
I check the hazard switch and nothing
click again
The hazard switch is under the glavels box
in the front,pasenger sidesjust remove the box and you can see the switch
Tray too change, iff not its the bad multifuction switch
190 dolars plus labourer
450-500 dolars
good luck
Old 06-26-2006, 10:48 PM
drdd's Avatar
drdd drdd is offline
do not replace the multi-function switch ...
... just clean it !!!
http://www.automotiveforums.com/vbul...d.php?t=577320
Thanks
Old 06-27-2006, 08:16 PM
excheezhead excheezhead is offline
[quote=drdd]do not replace the multi-function switch ...
http://www.automotiveforums.com/vbul...d.php?t=577320[/quote
yep, get 'er done!!
Old 07-08-2006, 09:50 PM
I clean today and dosent help
The sames clicking
Its the bad switch
THANKS
