Old 05-06-2006, 07:35 PM
DavidLang's Avatar
DavidLang DavidLang is offline
Water Pump O ring
Just finishing up an engine rebuild on my 91 3Cyl. I've tried 3 or 4 O rings on the out put tube of the water pump and it still leaks a bit. I was hoping to avoid using a sealant but will if I have to. Does anyone know of a source for better fitting O rings, or if I need to use a sealant what do you suggest? Thanks for any help.
Dave
Old 05-06-2006, 08:22 PM
geojim geojim is offline
Re: Water Pump O ring
When mine leaked on my '93 I got a replacement ring at the GM dealership parts department for a few bucks. Normally I avoid getting parts there, but in this case it was cheap and the correct size. They had it in stock and with a little grease on it, it stopped the leak behind the water pump.
1993 Geo Metro - 1.0, MT, A/C - 343K Miles
Old 05-07-2006, 07:25 AM
DavidLang's Avatar
Thanks GeoJim, that makes the most sense.
Dave
