Damper Removal On A 90 Bonneville
I Need To Know How To Get The Damper (crankshaft Pulley) Off Of A 1990 Bonneville!
Re: Damper Removal On A 90 Bonneville
go to autozone.com/repairinfo enter the car go to repair info for guidelines.
If it has 3 threaded holes in the front of it, it's pressed on and you'll need a balancer puller to remove it. If it doesn't have the threaded holes, the crank snout boltholds it on, and is REALLY tight (like 240 ft/lbs tight), and you'll need a humongo breaker bar and an assistant to hold the flywheel from turning while you break that bolt loose.
![]() Still waiting for the "good old days" I'll get to bore my future grandchildren with! |
