Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 05-06-2006, 05:43 PM
gilligan354 gilligan354 is offline
Del Sol no start problem
I have a 93 del sol. One day I was adjusting the power steering pump when it just quit on me. I have checked everything I can think of, including having my old auto tech teacher come and look at it. I've gone through the fuel pump, injectors, filter, distributor, ingition module, spark plugs, map sensor, ignition output signal, timing belt, tdc crank and throttle position sensors, ecu, main relay, and all of the fuses everything I can think of. When I crank it it seems like it wants to start, and when carb cleaner is sprayed inside it almost starts. Everyone of the things listed is fine. I am completely out of ideas. Any help will be greatly appreciated!
Old 05-07-2006, 11:29 AM
superbluecivicsi superbluecivicsi is offline
AF - Advisor
Re: Del Sol no start problem
your auto tech teacher readings on fuel pressure says? check engine lights? you visually see sparks coming to the plugs? battery voltage reads?
battery terminals are tight?
99 [email protected] psi si- I voted for the Terminator for Gov.
95 HB- B16a2- SC34@12psi
WTB: USDM B16a2 or B16a3 complete short block. pm is the key.
FS: B series InlinePro cast mani, PnH RC 550s, and Hondata S2b. pm me.
