Go Back   Automotive Forums Car Chat > GMC > Sierra
Old 05-06-2006, 05:40 PM
9TPI1GMC 9TPI1GMC is offline
Angry Alternator not charging
I have a charging problem it may be just a wiring problem but not sure right now, maybe someone else has had the same problem. I installed a chrome Powermaster alternator on my truck on the alternator there are two wires the battery feed and a brown wire I checked the voltage at the alternator and its 12.0volts not running and the same when it is running. I've checked all grounds to the frame,body,battery everything checks out ok my question is could the brown wire be causing the problem or maybe do I have to ground the alternator cause it has a chrome case around it?
Old 05-06-2006, 09:36 PM
Mr Wiggl3s Mr Wiggl3s is offline
Banned
Send a message via AIM to Mr Wiggl3s
Re: Alternator not charging
Year/Model?
Old 05-07-2006, 12:06 AM
Sorry I guess that would help it's a 91 GMC Sierra with a 5.7litre.
Old 05-07-2006, 03:42 AM
ffmilo ffmilo is offline
where does the brown wire go to?
