Old 05-06-2006, 04:07 PM
mdnnccivicrcr mdnnccivicrcr is offline
90/91 wiring into 88/89
I'm helping a local guy with a 89 STD hatch, we are going to wire up my tach cluster using a pin-out chart I made years ago, how about his engine wiring? His is a DPFI as well, in theory I should just be able to drop my D15 in and plug it in using my harness but do I need to pull mine off and use his? also are all of the sensors the same?
90 Civic EX *RIP*
90 CRX DX *RIP*
88 Civic DX Sedan (pushing boost) *RIP*
95 Accord LX Sedan
Old 05-06-2006, 09:32 PM
civic_boy91's Avatar
civic_boy91 civic_boy91 is offline
Send a message via AIM to civic_boy91 Send a message via Yahoo to civic_boy91
Re: 90/91 wiring into 88/89
if your going to run it dpfi it will all be the same...even if you run it mpfi...i used the stock harness and made it mpfi... what are you trying to do?... if its a cluster swap and you have a pin out it should work...maybe im just too tired to fully understand your question......90/91 dont work with 88/89...(for the cluster)
_________________________________http://VelocityFactor.com________________________________
1990 si hatch
b20b si tranny
megan race header 2.5 custom exhaust
50 shot
integra da rear disk (w/ 4040 valve)
powerslot rotors and barded lines all around
1994 Dx hatch
stock
Old 05-06-2006, 09:59 PM
it does if you re-wire the plugs and get the appropriate bezel
really, I'm trying to avoid completely re-wiring the whole car. I've done it before and it's not fun.
90 Civic EX *RIP*
90 CRX DX *RIP*
95 Accord LX Sedan
Old 05-06-2006, 10:12 PM
FrodoGT's Avatar
FrodoGT FrodoGT is offline
I second the "rewire blows" comment. Pins on the 88-89 and 90-91 are different..and I dont just think it is in the cluster either, I have an engine harness from an 88 HF and an interior harness from a 91 SI (dunno if that has anything to do with it) and when matched together..almost none of the wires matched.
Cheap, Fast, Reliable..Pick two
Current project:
Rio Red 91 hatch.
A6/Z6 build, Hondata S300, Tokico illumina/Ground Control.
"I'd rather run 12's on steelies than 15's on rotas."
Old 05-07-2006, 08:21 AM
bambam89lx's Avatar
bambam89lx bambam89lx is offline
AF - Advisor
Send a message via AIM to bambam89lx
harnesses between different years aren't the same at all. Not even the engine harnesses. I've seen a few times where I've tried using a 91 dx harness in a 89 dx or an 88 dx and it obviously plugs in, but some of the wires are in different locations on both sides of the plug, so you have to depin and repin them to the same locations for it to work properly.
Jumper harnesses, mpfi conversions, engine harness conversions, vtec subharnesses, etc.
The absolute lowest prices at the absolute highest quality. Trusted. Guaranteed.
Click the image above to visit our online store!
Hastings Bseries and Dseries piston ring kits (inc. ZC) - $49 shipped
Old 05-07-2006, 09:55 AM
Tony's Avatar
Tony Tony is offline
TLD Member #1
Send a message via AIM to Tony
I don't know about the engine harness, but the cluster will work if you rewire it. Don't know if you can just repin it or not, I just used the 88-89 plugs. I don't think the 88-89 bezel will work though, I believe the 88-89's bolt in different places, don't remember for sure, been several years since I did mine.
Tony
91 Civic Sedan DX - Stock 287k Miles
