Go Back   Automotive Forums Car Chat > Nissan > 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX > Technical
Technical Discuss Engine, Suspension, Drivetrain, and all other technical issues here.
Old 05-06-2006, 02:47 PM
1_revin_Silvia 1_revin_Silvia is offline
Send a message via ICQ to 1_revin_Silvia Send a message via MSN to 1_revin_Silvia
S15 6spd tranny question
Anyone know if the 6 speed tranny out of an S15 will bolt right up to an S14 chassis & SR motor? tranny mounts? are they the same?
RB26DETT swap into my 240sx S14 journal: http://www.cardomain.com/ride/2343921
Old 05-06-2006, 07:51 PM
MetalHeadZaid's Avatar
MetalHeadZaid MetalHeadZaid is offline
Re: S15 6spd tranny question
i dont think it will bolt up, but im not sure. i would rather have the 5 speed though, apparently its much stronger.
S13
Silvia Q's - R.I.P.
R32 GTST Type M Sedan - Sold
R32 GTST Type M Coupe - Sold
S14 Silvia K's - daily
R32 GTS4 - BETTER BE READY!!!
Old 05-06-2006, 07:56 PM
Yeah, was just a thought...Always looking for new ideas to bang around lol. a 6spd would be fun to have though. I cant see how it would be weak though, since its in the S15. Meh.
Old 05-06-2006, 08:04 PM
its weak because all 6 gears have to be thinner, so that they can fit in the same box as the 5 speed(?) and obviously thinner means weaker. from what i have gathered, 300 whp is about as far as you could safely go. also i have read that the 6 speed makes ALOT more noise, though that most likely doesnt matter to you.
hey, if you have an sr20, have a look at my thread in the off topic area : )
if this swap works and you decide to do it, i may be interested in your current 5 speed if you choose to sell it
S13
Silvia Q's - R.I.P.
Old 05-06-2006, 09:35 PM
sidewayzS13's Avatar
sidewayzS13 sidewayzS13 is offline
doin it sidewayz
Send a message via AIM to sidewayzS13
you should get a z32 tranny.
and somebody sigged me i feel loved
Originally Posted by Muscletang
I say let it run its course. Most women experiment with things. They'll try something whether it's mind altering drugs, going down on their best friend, an Emo song, or plastic surgery.
Old 05-06-2006, 10:39 PM
wotandsdwys wotandsdwys is offline
swap the bellhousing to your S14 housing, and It should bolt up.
Old 05-06-2006, 11:22 PM
doin it sidewayz
Old 05-06-2006, 11:26 PM
Yeah i most likely wont bother, but it was just an idea. No point in fixing what already works good i guess huh?
Old 05-06-2006, 11:30 PM
doin it sidewayz
no this is the time where you trash your tranny and get the z32
Old 05-07-2006, 12:37 AM
im guessing the z32 trans mounts up to the KA and SR? gearing any lower? whats so good about them?
S13
Silvia Q's - R.I.P.
Old 05-07-2006, 09:53 AM
i second that
Old 05-07-2006, 07:39 PM
doin it sidewayz
you have to buy a bellhousing adapter for the sr from i think maz works or something like that
i dont know if its made for a ka
anyways it can easily handle like 600 hp its a fucking beast it will not fail all the high power sr guys are starting to switch to it
Old 05-07-2006, 09:02 PM
badass...I'm gonna research that. Sounds like a fun project!
Old 05-09-2006, 11:42 PM
2.4L of Torque 2.4L of Torque is offline
Theres 2 guys locally who have done both Z32 Auto and 5-Spd swaps on their KA-Ts. They just used 1/2" bar plate steel and drilled new patterns for the Z32 tranny. Cut out a hole in the Z32 tranny for the KA starter.
Old 05-12-2006, 08:35 AM
Tim Megenbier Tim Megenbier is offline
Send a message via AIM to Tim Megenbier
Does anybody know what is needed for the Z32 for the KA? SR20?
1. Is the output shaft from the trans (splines) the same?
2. Clutch assembly, KA or Z32?
3. Gearing?
4. Driveshaft needed to be changed, shorted, etc?
5. Speedo bolts right up?
6. Mounting brackets or trans mounts?
7. What year R32 trans?
8. Turbo or N/A?
9. Slave connection, hoses, etc?
10. What kind of adapter plate, spacer is needed?
Any info on a sequential shift pkg for the R32 trans?
I have a racing gear company that can produce the adapter plate, shafts, etc. If this works, I can manufacture the needed parts and sell it in a kit form.
