Go Back   Automotive Forums Car Chat > Nissan > 240Z | 260Z| 280Z | 300ZX (Past Z Cars)
240Z | 260Z| 280Z | 300ZX (Past Z Cars) The original Z cars - ones that started it all.
Old 05-06-2006, 11:43 AM
figo_madrid04 figo_madrid04 is offline
Send a message via AIM to figo_madrid04
need the specs for all hoses and lines in a Z32
I got through rebuilding the valvetrain in my 91 tt and i still have some sort of knocking noise, i changed everything except for the (lifters , lashers, or rockers) i dont know which the 91 tt has, but im pretty sure thats where the knocking noise is from ... btw its only in the 1st and 3rd cylinder...... sooo getting my question,
does anyone know the specs on the vaccum, fuel, lines etc etc....
how many , how long each one is etc...........
i have to pull the engine back out and ive noticed some of the lines are cracked and worn out .......i dont think i have any leaks but i will in the near future if i start boosting any higher..... in any case i would appreciate if someone knows what types, how long, and how many of each hose i need so i can buy the right amount ......
thanks a bunch....
Old 05-06-2006, 01:25 PM
DeleriousZ's Avatar
DeleriousZ DeleriousZ is offline
Send a message via MSN to DeleriousZ
Re: need the specs for all hoses and lines in a Z32
just buy like 25 ft or so and if you run out, get more :P
i dunno, do you guys have an FSM readily available for the z32? that should tell you where all of them go...
ZedEx Crew Member #6
1988 300zx turbo 5spd. 3" mandrel exhaust, filter, afco rad, e-fan, poly engine mounts, mbc at 8.5 psi, turboxs rfl-h bov, gutted plenum, etc.
blown turbo, under construction.. gt35 coming.
Old 05-07-2006, 02:14 AM
isn't there diffrent types and rating for the diffrent types of hoses?....... ie. fuel and vaccum?
Old 05-07-2006, 02:27 AM
DeleriousZ's Avatar
yeah there was different sizes of fuel line and everything... you should use the fuel line for fuel and well.. vacuum hose for vacuum... perhaps one who owns a z32 could help you better
Old 05-08-2006, 12:36 AM
ExTrEmEDrIfT's Avatar
ExTrEmEDrIfT ExTrEmEDrIfT is offline
Send a message via AIM to ExTrEmEDrIfT Send a message via MSN to ExTrEmEDrIfT Send a message via Yahoo to ExTrEmEDrIfT
no not off hand ... take off a couple hoses take them with you to store that sells the hoses - pep boys whtever - and there you go , just get some high pressure hoses...
Past Z Car Crew
[The Enemy Of Your Enemy is Your Friend]
>>Keep Your Friends close : But Keep Your Enemies Even Closer <<
