Old 05-06-2006, 10:08 AM
garync1 garync1 is offline
2001 Windstar Fuel filter replacement
http://2001windstarfuelfilter.blogspot.com/
I posted some pics one my blog to show the replacement of the fuel filter on the 2001. It was alot easier than I thought, without the use of quick disconect tool as I thought would be needed. The picture for releasing the fuel pressure is at the bottom.. sorry I tried to put in order but something changed when I was done..hope this helps. Gary
Old 05-06-2006, 01:37 PM
lewisnc100 lewisnc100 is offline
Re: 2001 Windstar Fuel filter replacement
I was surprised as well when I replaced it on my 2000 a year or so ago. Felt silly trying the quick disconnect tool I had bought and then realizing you just squeeze the tabs and pull apart.
1997 Pathfinder XE
Air Lift Air Bags, Warn Hubs
2000 Windstar SEL
Old 05-06-2006, 09:05 PM
wiswind wiswind is offline
For those of us with the older windstar, the tool is needed for the forward most connection.
Sounds like they made a good improvement in the newer model.
Moderator for Ford Windstar room only
Links to my pictures, intended as an aid, not a replacement for, a good repair manual.
1996 3.8L Windstar
http://www.flickr.com/photos/4157486...092975/detail/
2003 Toyota Sienna pictures (not much there yet)
http://www.flickr.com/photos/4157486...781661/detail/
Old 05-07-2006, 08:00 AM
I did as well, buy the tool and found out it was not needed. In the book it said some of the vans came with the tool snaped in a location beside it.Never found it of course.. Maybe some of those out there that need the tool may look around and find one snaped in its location.. I wanted to let the ones know on the same model as mine that the tool was not needed and its a good thing that needs to be replaced. My chevy malibu has 135,000 + miles on it most were my wifes miles before we were maried and it had never been changed. I have all sorts of minor performance problems with the injectors because of this.. Low idle,misfires in cyclinders and other minor issues.I only drive it to work so I only do little work to keep it going. It runs fine but it could run better. But I am almost sure if the fuel filter was replaced earlier I would not have these problems.. I may need to clean the injectors one day on the malibu but I only drive it to work so its not priorty.. Hope this helps..
Old 05-07-2006, 12:09 PM
Yeah, I guess I could have posted that info in a more prominent spot than buried in this post:
http://www.automotiveforums.com/vbul...ht=fuel+filter
1997 Pathfinder XE
2000 Windstar SEL
