Old 05-06-2006, 07:59 AM
altautoman altautoman is offline
Need Injector Help for 4.3 Chevy
I have a 2000 Chevy S10 4.3 "W" Engine. I recently installed a .500 Lift Comp Cam, V-Max Intake Spacer, Ported my heads with a valve job. I now am starving for fuel out of the hole. I was told I need stronger injectors to solve this problem. If anyone knows where I could find these please let me know.
Old 05-06-2006, 08:02 AM
maxwedge maxwedge is offline
A990 racer
Re: Need Injector Help for 4.3 Chevy
Make sure you have 65 psi fuel pressure, this is a vortec cpfi right.
Old 05-06-2006, 08:33 AM
Vehicle has excellent fuel pressure, 64 PSI. When connecting OBDII to system, it show misfire in all cylinders at idle. When reving motor all misfires go away. Once you are driving at get on it, vehicle response in excellent. It only seems to have fuel problem when leaving a standstill.
Old 05-06-2006, 03:55 PM
A990 racer
If the injectors were undersized the power loss would be at high rpms, how is the idle vacuum with all the mods?
Old 05-06-2006, 04:01 PM
RahX RahX is offline
If it's starving for fuel out of the hole then you need to get the idle-part throttle mixture up. You should only need stronger injectors if it starves for fuel when you tromp on it and the injectors are working hard.
Old 05-06-2006, 10:31 PM
dmbrisket 51's Avatar
dmbrisket 51 dmbrisket 51 is offline
Send a message via AIM to dmbrisket 51
you need to call jet chips and tell them what youve done, and be prepaired to spend over 400 buck, you need a chip cut for that cam
Old 05-07-2006, 07:42 PM
Is there an easy way to check vacuum, or adjust idle mixture? I noticed today even if I start out of the hole with a power brake, vehicle hesitates for a couple of seconds then revs very fast, spinning tires. But when you let off the brake it will cut out again then kick in antoher couple seconds later. I will call Jet and see how much more money I can spend. Its only money right. As long as the wife doesn't know. I appreciate all the help you guys are giving. This site is has excellent communication!
Old 05-07-2006, 09:11 PM
spray carb or break cleaner around suspected areas to check for vaccume leak, but idel is non adjustable
Old 05-17-2006, 07:29 AM
Thanks for the help, found obvious vacuum line not connected. Don't know how I missed it, truck runs great! Has anyone ever used the Comp Fast Flash programmer? I just ordered one, they claim you can change your fuel/air ratio and dial in your cam with your computer.
