Old 05-06-2006, 12:34 AM
2000LS1Z28 2000LS1Z28 is offline
Don't think i'm gonna get what I want for the car, need advise
Alright, first I gotta tell you. I don't give an F what anybody says here, bone stock F Bodies suck ass handling wise. My former Evo would literally decimate any of my buddies with full on suspension upgrades on their car (adjustable shocks, struts, torque arm, parhard rod, sfc's, strut tower brace, etc...).
I need this car to be able to handle, cause quite frankly it is driving me nuts. It wallows into corners, and just flat out feels like a fat opera singer trying to pull off a break dancing move.
What type of suspension upgrades would you guys recommend? I can't lower the car, as I plan on boosting it with the STS kit, and the turbo will sit in the back, thus it will get damaged if it is lowered (Trust me I know, my buddy has the kit, and his car is lowered, sucker scrapes often). I already have the following suspension upgrades: panhard rod, strut tower brace and lower control arms.
Plans are to add the STS turbo sometime around next year, but to first work on the suspension.
Oh, and a good clutch option would help too, as i'll most likely be pushing 8psi when all is said and done.
2001 MR2 Spyder
Magnaflow Muffler and OBX CAI.
Old 05-06-2006, 03:19 PM
DarkblueTA's Avatar
DarkblueTA DarkblueTA is offline
Send a message via AIM to DarkblueTA
Re: Don't think i'm gonna get what I want for the car, need advise
AWD is going to handle better then RWD stock for stock. You want it to handle...do the following and you'll have a corner carver. (BTW, I have a rearmount on the car too...)
1. Subframes(weld in kind are the best)*probably the best thing I ever did to my car)
2. Sway bars*
3. Poly tranny mount*
4. Torque Arm*
* should be able to do yourself and you can weld in the subframes if you have welding equipment.
Now, as far as shocks(keep the stock springs for ride height that you'll need with the STS kit) its up to you. I used the KYB AGX shocks on all 4 corners. fronts are set to "5" and rears to "4". Slightly stiffer then stock ride but handle bumps/road conditions great!
Also, tires are a HUGE difference!!!! HUGE. Make sure you have a good set on. I <3 my BFG g-Force tires.
Clutch...I have a Spec stage 4i. I have used a Stage 3. Make sure whoever installs it knows what they're doing. On LS1's stay AWAY from Centerforce. I'd also advise putting a new slave(GM 145) in and a new master cylinder.
With the STS kit, get the T67 upgrade. You will also need to purchase a fuel pump, 60# injectors and an OBX intercooler off ebay. Get some piping and couplers and put the intercooler on yourself. It will save you some cash also.
If you're in South FL, I can help you mod the car if you want. Everything but the subframes and torque arm I have done on my TA(I have subframes I didn't weld them in and torque arm is going on while its getting the engine/roll cage in).
If you need a place for parts, contract Robert, Jason or Able at Extreme Performance. (www.extremeperformance.org). They are in OKC, stand up guys and that is where my TA is at currently getting a new engine, roll cage and other things taken care of and I don't just let anyone touch my car. Just tell them Matt(darkblueta) told you about them and they'll take care of you.
Good luck and welcome to the world of Fbodies.
DarkblueTA
GT70, FMIC, Alky-water injection, Hooker Cat back, 208/230 .549/.579 121LSA Cam, forged diamond pistons/eagle rods, LS6 block, Lakewood LCAs, BMR STB/PHRB/Sway Bars, poly torque arm bushing, Spec Stage 4i clutch, B&M Ripper Shifter, SLP Subframes, 60# injectors, KYB AGX shocks/struts, Moser 12 bolt(373 gears, 33 spline axles, posi, ta girdle/etc/etc/etc) and HPTuner kit
2007 Nissan Titan Daily Driver. 2* advance
Old 05-06-2006, 07:49 PM
I'll be going into Florida for the IT program the Navy is sending me too. Most likely i'll be there from September through December. Dunno if I can bring my car though. That's alot of miles to drive it, and I don't plan on moving it till I officially move out of state (To wherever they station me at). I do appreciate your offer though. I'm definitely going to have to consider the subframe connectors and the KYB's.
2001 MR2 Spyder
Old 05-06-2006, 08:27 PM
Mr. Luos's Avatar
Mr. Luos Mr. Luos is offline
Firebird Guy
Panhard bar!!!!
Keep that rear centered.
1999 Pontiac Trans Am WS.6 #1747
Stock'ish'
Old 05-06-2006, 09:18 PM
DarkblueTA's Avatar
Originally Posted by Mr. Luos
Panhard bar!!!!
re-read his post...he's already got it
DarkblueTA
Old 05-06-2006, 09:24 PM
Mr. Luos's Avatar
Firebird Guy
Damn it.
Adjustable?
Stock'ish'
Old 05-07-2006, 01:28 AM
It's not an adjustable panhard rod. I'm going to purchase the KYB's when I come back in December, and have some subframes ordered by then too. Already looking into the STS Turbo kit pricing wise. Just need to have a good 520whp, so I can keep up with those punks in modified 520whp 300ZXTT.
I hope you guys are right, and that this car can have potentially good handling, as that was the main reason I considered selling it.
Sometime in 2007 I should have everything together and in. I'm hoping to match or beat you Luos, atleast on the dyno, and with less cubes.
2001 MR2 Spyder
Old 05-07-2006, 09:28 AM
Mr. Luos's Avatar
Firebird Guy
Yeah...but with boost. And they are only dyno numbers.
Stock'ish'
Old 05-07-2006, 02:24 PM
doodad's Avatar
doodad doodad is offline
Send a message via AIM to doodad Send a message via Yahoo to doodad
even if you beat Luos on dyno or track.. l would still respect his car more than yours.. because he puts down 520RWHP ALL MOTOR!!!
Erdal
Old 05-07-2006, 02:27 PM
DarkblueTA's Avatar
HUH? have you trapped 124mph yet?
my 12.2 was on street tires though.
DarkblueTA
Old 05-07-2006, 08:45 PM
Mr. Luos's Avatar
Firebird Guy
If I was sea level...I would be trapping 126 MPH this wednesday.
But since I am here...looking for 116-117.
Stock'ish'
Old 05-07-2006, 09:03 PM
CreepingDeath94 CreepingDeath94 is offline
Oh yea, well my F-16 traps like 300 or something!
Old 05-07-2006, 09:40 PM
DarkblueTA's Avatar
LOL nice. I wasn't near sealevel...that was in Vegas DA was around 2500 in the winter
I better trap 130+ when the TA is back.
DarkblueTA
Old 05-07-2006, 09:41 PM
Mr. Luos's Avatar
Firebird Guy
Dang.
Stock'ish'
Old 05-07-2006, 09:44 PM
DarkblueTA's Avatar
Dang.
Yeah...a bit faster then the 13.7@104 my Z ran this weekend. I can't complain, there was a 98 TA out there A4 /323s with a lid and he ran 13.8@101. the other pre 01 LS1 Fbodies that were stock/close to stock were about the same. I hate Moroso on Test and Tune, they don't lay any VHT down.
DarkblueTA
