Go Back   Automotive Forums Car Chat > Pontiac > Bonneville
Old 05-05-2006, 07:13 PM
trigga_b trigga_b is offline
does supercharger work?
how do you tell if your supercharger is working? also what is the difference between the sse and the ssei
Old 05-05-2006, 09:46 PM
bocoogto bocoogto is offline
Re: does supercharger work?
If you're supercharger is working, the front wheels will spin in first gear at any speed between 0 and 25 mph. Also, the boost gage shows you if the supercharger is working. It should nearly peg with the throttle wide open in any gear.
The only difference between the SSE and SSEi is the supercharged engine, HD trans., and lower rear axle ratio.
Old 05-06-2006, 07:06 AM
i dont have a boost gage or i cant locate it
Old 05-06-2006, 08:19 PM
jdq jdq is offline
If you dont have a bosst gauge then you probably dont have a SC.What year is your car
2000 bonn ssei 155000 klm
1997 dodge caravan 92000 klm
Old 05-07-2006, 09:18 AM
92 bonneville sse i see the supercharger under the hood but no boost gauge
Old 05-07-2006, 10:47 AM
jdq jdq is offline
SSEI is supercharged , SSE is not did you just buy this unless someone put in a new engine or something
This what a supercharger looks like,this is a little diff than yours should be but same idea
http://cgi.ebay.ca/USED-GM-SUPERCHAR...QQcmdZViewItem
Old 05-07-2006, 11:57 AM
mmmmm dam ima have to look under the hood cuz i just bought a starter for the supercharged bonneville and i already put it on there.
Old 05-07-2006, 04:49 PM
jdq jdq is offline
Well if it works maybe it is the same starter.
Old 05-23-2006, 06:32 AM
GTRider0 GTRider0 is offline
Send a message via AIM to GTRider0 Send a message via Yahoo to GTRider0
the sse was offered with a supercharger i bought one with 15 miles on it in 92 stock with a supercharger from a pontiac dealer and mine didn't have a boost gauge either but you can buy triple gauge pods at summit.com and put a boost gauge in yourself
Old 05-23-2006, 09:44 AM
BNaylor's Avatar
BNaylor BNaylor is offline
I agree. The '92 SSE was available with the Series I 3800 V6 supercharged "Vin 1". The 8th digit of the VIN number will have a "1".
As mentioned by the previous poster you can get an aftermarket boost gauge like an Autometer Phantom for under $40 which will tap into an engine vacuum source such as to the MAP sensor.
Timeslip 08/12/06
AF Community Guidelines
Old 05-24-2006, 05:31 PM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
This whole thread is a little scary, yikes!
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Old 05-24-2006, 06:29 PM
BNaylor's Avatar
Its not that bad Rich. I've seen worse. At least these guys are civilized unlike in the Chevrolet forums.
Timeslip 08/12/06
Old 05-28-2006, 11:07 PM
83scottsdaleowner's Avatar
83scottsdaleowner 83scottsdaleowner is offline
Send a message via MSN to 83scottsdaleowner
ok if your engine bay looks like this...
Then you have a supercharger...
if it looks like this... w/ out the intake of course..
then you don't have a supercharger...
simple as that and yes some sse's did come w/ superchargers
also if you wanna know where the boost gauge is - - if you have one it is located here...
1992 Pontiac Bonneville:
