Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse 2000+
Old 05-05-2006, 03:10 PM
Eclipsebella86's Avatar
Eclipsebella86 Eclipsebella86 is offline
Unhappy clicking sound??
when i press on the gas to back up i hear a tiny click sound and the same thing when i put it in drive when i tap the gas. Its nothing loud but it bothersome??? ne thoughts boys??
i dont have a manual its a semi-auto
2001 gs
Cardomain: http://www.cardomain.com/ride/2249920
Dark Butterfly:
Vibrant Strut Bar
Full Eclipse Sound System (2 12"s, 4 door speakers, 2channel amp and 4 channel amp and deck)
pink plasma glow neons under the dash (cuz Im a girl)
Custom sub enclosure (http://www.cardomain.com/member_page...20_43_full.jpg)
pink trim
Blitz Kit
pink grill mesh
10% tinted windows
Old 05-05-2006, 03:17 PM
808drifter 808drifter is offline
Re: clicking sound??
this has been discused already. plz search for it.
Old 05-05-2006, 04:00 PM
rodbls's Avatar
rodbls rodbls is offline
Send a message via AIM to rodbls
this place has been pretty dead, so I will put my 2 cents in. It could be a number of things. CV Joints, Stearing knuckle, transmission, bad half axel, wheel bearings. Anything that move on the front end that is broken can make a clicking noise. Does it do it when the wheel is str8 or turned or both. If it does it when the wheel is turned it may be CV joints or Stearing knuckle. If it does it str8 then it could be all of the above. Get it checked out because it will probably get worse.
2000 Fed. Spec GT-"Lafawnduh"
Mods: SPEC 2+ Clutch, Fidanza Flywheel, PowerStop Rotors, Red Stuff Pads, Stainless Brake Lines, B&M Short Shifter, Energy Suspension Shifter Bushings, Deyeme Firm Motor Mounts, KYB AGX shocks with Eibach Proline springs, Halo Projector Headlights with HID 12000K Conversion, TYC Carbon Tails, Kicker SS6.5 Component Front, SS MB8 Custom rear, Tsunami 2F Capacitor, ***New Stuff*** JVC KD-AV7010 In Dash DVD Player, Kicker L7 12" Woofer, Kenwood KAC-X10D Mono Amp
Old 05-06-2006, 12:36 AM
Sleepr awd's Avatar
Sleepr awd Sleepr awd is offline
Send a message via AIM to Sleepr awd Send a message via Yahoo to Sleepr awd
i'd go with motor mounts depending on how the car is driven. if it only does it under a sudden short burst of gas, it might just be a motor mount that is broken/worn/ normal
Don't act like you don't love it.
503/2000
Old 05-06-2006, 02:46 PM
it happens when its straight, when i out it in reverse it clicks when i tap the gas and when i put it back in drive it does it again
Dark Butterfly:
Vibrant Strut Bar
pink trim
Blitz Kit
pink grill mesh
10% tinted windows
Old 05-06-2006, 05:46 PM
rodbls's Avatar
It may be motor mounts (frankly, anyone with more than 40K miles and stock motor mounts probably should replace them because I wouldnt doubt that they were shot the moment they put them in the car at the factory). Motor mounts usually make a squeeky, bumping sound, and cause a rough idle. It may be a contributing factor though. You arent talking about the noise your transmission makes when you change from R to D are you? That is normal. From how it sounds it sounds like a drivetrain joint of somekind. There are so many things that it could be, your best bet is to at least get it checked and diagnosed, and see what your best option for fixing it is. Unless it's under warranty dont get it fixed at a dealer. Does the noise ever stop, like, it does it all the time when you stab on the gas, or just when you get going? From my experience it sounds like CV/Half axel.
Old 05-06-2006, 09:35 PM
it makes the noise when i first hit the gas after putting it in reverse and when i put it back into drive it clicks when i first hit the gas, its not an ongoing sound only those 2 times
Dark Butterfly:
Vibrant Strut Bar
pink trim
Blitz Kit
pink grill mesh
10% tinted windows
Old 05-07-2006, 12:55 AM
rubix777's Avatar
rubix777 rubix777 is offline
Send a message via AIM to rubix777
Mine is manual and I think I know what you're talking about. It makes one click when I tap the gas when accelerating from a stop. It actually makes that click when the car's weight is shifting from the front to back (or vice versa) which makes me think it's coming from the suspension--kind of like a creaking or as if the screws aren't tight and the springs move around.
Old 05-08-2006, 09:11 AM
thats exactly it, 1 click when i tap the gas
Dark Butterfly:
Vibrant Strut Bar
pink trim
Blitz Kit
pink grill mesh
10% tinted windows
