Go Back   Automotive Forums Car Chat > Jeep > Grand Cherokee | Grand Cherokee SRT8
Old 05-05-2006, 12:40 PM
eraseraj's Avatar
eraseraj eraseraj is offline
Send a message via AIM to eraseraj
Cool 1994 jeep Trans.
back to get more good advice from AMF
Ok when my jeep is shifting gears going up a hill it jolts into first real hard then back to second within 1 sec. it seems it shits to many times like it is confused. second thing the trans. does, is shift from third to second countless times going 30 mph not changing speed and everytime it shifts the jolt is so hard it feels like the bottom of the jeep it going to blow off. I have had the speed sensor fixed but that only helped my overdrive shift. My low speed shift is still all messed up. Oh the jeep has 122,000 miles if that helps
if anyone can help please respond
1994 Jeep Grand Ltd.
Old 05-05-2006, 02:35 PM
JDPascal JDPascal is offline
Re: 1994 jeep Trans.
Hi eraseraj
You likely know this one and have done it allready but just to be sure - check the fluid level - hot if possible.
after that, the next items to check are the throttle cable adjustment and the band adjustments.
How long ago was the last transmission fluid change???
JD
If ya can't fix it right the first time, how ya goin ta find the time ta fix it again????
Old 05-06-2006, 08:20 AM
eraseraj's Avatar
the person who owned the jeep before changed the fluid once at 50,000 miles but that was about all. I am going to try changing it and see what happens but if the trans. still shifts bad does that mean i may have to get it rebuilt
Old 05-06-2006, 11:34 AM
When you pull the transmission dipstick, What does the oil smell like??
If it smells burnt, hopefully you can catch it in time
While it is possible that a tranny rebuild is in your future have the
  • fluid changed
use ATF+4 if it is a chrysler transmission
dexron if the AW4
  • bands adjusted
the chrysler transmissions have one band inside the pan and one outside
the AW4 is not adjustable
  • throttle cable adjusted
By a qualified person that is trustworthy .
Some times the Governor assembly gets stickey and hangs up. If the person doing the service is knowledgeable they will know what to do. There are other things that will screw up the shift but start with the easiest stuff first.
JD
Old 05-19-2006, 12:52 PM
eraseraj's Avatar
Exclamation Re: 1994 jeep Trans.
well i Finally got the trans. acid flushed. and all new fluid put in it. my rough shift has stopped, and random shifting is gone, however when going around corners, and slowing down wile making the turn it will down shift to first gear and it will not stay in for more then an 1/2 a second then it will go back into second but it does it more then once on the same turn. It will do it 3 times (1st to 2nd to 1st to 2nd then continue like normal) is this bad for it? does it need to be reajusted? Could it need rebuilt? is there away to make it last another 20,000 miles if it does need rebuilt? I have money issues becasue i am in highschool and saving for college.
If anyone can help please respond.
thankyou
Old 05-20-2006, 09:55 AM
ACID flushed
Who did the flush??
What ATF did they put in??
Did they remove the pan??
Did they adjust the bands for you??
Ya! a rebuild might be in your future but (see my last post).
JD
Old 05-22-2006, 11:52 AM
eraseraj's Avatar
I am no car expert but they said they had to adjust something, so I am guessing it was the bands. Now the type of trans. fluid, I do know it was not ATF+4 it was ATF+3 and when I said to the guy are you sure it's +3 he said it was the right kind and he knew what he was doing. Is This person full of crap?
Old 05-22-2006, 06:56 PM
mx52nv's Avatar
mx52nv mx52nv is offline
most shops use mercron(sp) with the Chrysler friction modifier additive. very few shops actually use atf+3 and rarely will you find atf+4 in a shops tanks. here in town we have one of 22 shops in the country that has the atf+4 and the atf+5 full synthetic in his tanks.
current rides:
1990 Turbo Miata
lifted and locked 96 Grand Cherokee with other toys under the hood
retired rides:
1996 Eclipse GSX
1991 Stealth
1991 Porsche 993 C2
1988 BMW 520i
Your SUV isn't a Jeep, and my Jeep isn't an SUV....
SCCA, where you actually learn to drive
Old 05-07-2007, 08:22 PM
danielle41852000 danielle41852000 is offline
Unhappy Re: 1994 jeep Trans.
how long will a new transmission last and how long will a use one last to
Old 05-09-2007, 09:18 AM
JeepForever JeepForever is offline
I had the transmission rebuilt at around 160,000 miles (1994 Jeep GC). The tranny shop said they prefer to rebuild them themselves rather than buying a new one (I don't think you really get a NEW one - just one that someone else rebuilt). He said he prefers to do the rebuild himself so he knows what goes into it. My understanding is that the rebuilt transmission is as good as new (although there are other parts around it that are still old). That should last for another 100,000 miles or more (hopefully much more if you continue to change the fluid periodically).
I've generally heard that FLUSHING an old transmission is a BAD idea - something about dislodging particles or causing problems that you didn't have before. It's best to drop the pan, change the filter, and refill the fluid.
You might have a new or rebuilt transmission in your future. Plan on around $2000, which could include a new radiator if there are restrictions in the transmission cooling system. It's tough to put off a major repair that might leave you stranded somewhere. I drove mine until the gears were shifting so badly that I realized it was about to die. The tranny place agreed, and I've been happy ever since it was rebuilt (except for some leaks a few weeks later, which they fixed under warranty without any dispute).
Old 05-09-2007, 10:24 AM
fredjacksonsan's Avatar
fredjacksonsan fredjacksonsan is offline
Caution: Monkeys bite!
Send a message via AIM to fredjacksonsan
eraserj, since you've got new fluid in and some of the shifting is still funky, you may want to have a look at the CPS (crankshaft position sensor) my 2000 4.0 shifted back and forth like that at times before I replaced the CPS.
danielle41852000, Welcome to AF! I'm sure you'll find some good information here.
A brand new transmission, with proper care and fluid changes, should last well beyond 200000 miles. If you get a used one, you also get the maintenance, or lack thereof, from the previous owner, so how long it lasts is a question to be answered down the road.
You may also want to consider rebuilding your current transmission. This will cost more than a used one, but less than a new one, and in many cases (if done by a reputable shop) it will give you the same longevity as a new trans.
Ours: 2020 Jeep Wrangler 2.0, 53k
2013 Toyota FJ Cruiser, 84k
Kids: 2005 Honda CRV, 228k
Old 05-26-2007, 02:46 AM
Bernando1 Bernando1 is offline
dont worry about the transmission. ATF+3 is just fine for Cryslers, synthetic is good, but your car has 120,000 miles on it-if any damage has been done, it is done already. A power flush is good.
Old 05-26-2007, 08:31 AM
bringselpup's Avatar
bringselpup bringselpup is offline
X2 on the ATF +3 that stuff will be fine for a 94 tranny.
You need to hunt down a reputable shop that won't just quote you a rebuild. There are some electronic valve controls accessable if you take off the underside pan that aren't a real pita to change out and usually the cause of the funky shift.
93 ZJ White 4.0L PowerTech I6 with +215K miles - Brembo up front Yakima on top Red Top under the hood
