Go Back   Automotive Forums Car Chat > Nissan > Older Pickups
Old 05-05-2006, 01:34 AM
yogiebear yogiebear is offline
92 4WD 4 cylinder stumbles
The car only bogs at low rpm's when your accelerating in evey gear, but stops "chugging" and runs smooth at higher rpm's. Also if you are idleing and rev it up to 2000rpm it wont stay on 2000rpm. I changed the spark plugs and spark plug wires, turned up idle speed and set the timing, and changed the fuel filter. It runs perfect if i spray carburator cleaner in the carburator before i drive it but that only works for a short time then it starts to bog again.
Thanks in advance
Old 05-06-2006, 08:51 PM
FixUrNissan's Avatar
FixUrNissan FixUrNissan is offline
Re: 92 4WD 4 cylinder stumbles
Check compression on #4 cyclender if ok , then it is possable it's and injector or a intake manifold leak.
While it's running , Spray your carb cleaner along the intake manifold, If it clears up for a second , then it's a leak from the gasket. Gasket woudl need to be replaced.
GL..
Old 05-10-2006, 06:55 PM
Re: 92 4cyc stumbles
Car still boggs around 1800-2000rpm but if u drive car without the air filter the car barely boggs and only when ur in 1st and 2nd gear. please post any more ideas on how to fix my problem thanks.
Old 06-22-2006, 05:43 PM
I fixed it by replacing the throttle position sensor
