Go Back   Automotive Forums Car Chat > Pontiac > Fiero
Old 05-05-2006, 12:45 AM
mruziruzi mruziruzi is offline
please help!!! fiero wont start
i have a 1984 fiero . new fuel filter , electric fuel pump, new fuses, and it sont start. gas is not being sent from the fuel pump. if i put gas directly into the throttle body it starts for 2 seconds. what could be the problem.
Old 05-06-2006, 07:13 PM
ctesla's Avatar
ctesla ctesla is offline
Re: please help!!! fiero wont start
-Uzi,
Welcome to AF. HOW did the vehicle "stop"? did it sit overnight, and it just doesn't fire? were you flying' down the highway, and it shut off? or did you clip a curb avoiding grandma in cottonwood, and then nothing...?
I mean it could be a bent or crushed fuel line, being one off the lowest stock made vehicles; however, if this is not the case, then I'd start by buying a $6-10 "noid" test light from AutoZone, or CarQuest, etc. and plugging this in by the injector. it could be that the injector is clogged and/or damaged; thereby not getting electical input and/or not opening to spray the fuel...
OR
it might be a fuel pump relay; which is another $6-10-15 dollar part that would interfere with fuel delivery.
since the engine fires while manually spraying a fuel substance down its throat (TBI), you at least know that it is a minor, not major problem; and you have isolated it as a fuel delivery, not ignition or air intake, etc...
hope this helps,
ctesla
nrt racing
Old 05-08-2006, 03:16 PM
southerngent56 southerngent56 is offline
Could be as simple as the fuse for the fuel pump, so eliminate that first.
Old 05-08-2006, 03:38 PM
Could also be the fuel pump relay, the oil pressure switch, or the ECM. You may need a schematic to aid in diagnosis as well as a fuel pressure gauge.
Old 05-15-2006, 07:06 PM
Originally Posted by ctesla
-Uzi,
OR
hope this helps,
ctesla
nrt racing
the car was parked for about 4 years and only started two or three times. after putting in new parts and new battery it never ran. then after four days i tried starting it again and now the new battery is completely dead!
Old 05-15-2006, 07:09 PM
thank you, i will have these checked out, but now the new battery is completely dead after about four days.
Old 05-15-2006, 07:10 PM
thank you, i will check these out, but now the new battery is dead after about 4 days.
