Old 05-05-2006, 12:06 AM
northriverflames northriverflames is offline
Send a message via MSN to northriverflames
Question Option packages when purchasing a DSM?
Hey Im curious about what option packages were available when buying a new 90-94 dsm from the dealer. I know some had power belts/cd/sunroof ect.....im just curious about what packages were out there. Im also wondering about a possible power seat belt conversion? I had them in my old car, but not in my current DSM. If anyone knows or can give me a link that would be cool thanks.
P.S. I have tried searching but im having no luck.
2000 Chevy Silverado 1500 4x4 Extended Cab.
1996 Pontiac Sunfire GT 5 Spd.
1992 Plymouth Laser RST AWD 5 Spd.
Old 05-05-2006, 12:35 AM
ez1286's Avatar
ez1286 ez1286 is offline
Send a message via AIM to ez1286
Re: Option packages when purchasing a DSM?
I'm not sure of the option packages but i'm sure it would be a huge pain in the ass to do a conversion. You will have to replace the whole trim above the door, and you may need a different switch on the door to turn them on and also an ignition switch.
95 GSX:FMIC, 6-bolt, evo 3 16g, 2600 act clutch, 1g bov (crushed), and a 3" turbo back exhaust, dsmlink, dks 272 cams, wideband 02, Coming soon 2.3L Stroker, 1mm oversized valves, crower sprigs. 91 TSI AWD auto, gm 3.5 maf, maft, fmic, emanage, profec e-01, 3" turbo bk exhaust +more little stuff.
http://www.ratemydsm.com/member/ez1286/?member=ez1286
Old 05-05-2006, 12:49 AM
wanaplay134 wanaplay134 is offline
Send a message via AIM to wanaplay134
why would you want to anyway i have them in my 92 talon and wish i didnt
1992 eagle talon tsi awd
xtd stage 3 six puck/apexi 3' downpipe and exhaust/ngk plugs/taylor thunderbolt wires/manual boost controller set at 20psi/walbro 255 with rewire/autometer boost gauge/turbo xs rfl blow off valve/arp headstuds/ to4b vtrim turbo/dnp tubular manifold with o2 housing and tial 38mm wastegate/eagle rods/ross pistons/acl bearings/arp rod bolts/arp main studs/aeromotive fuel pressure regulator and all stainless lines/aem fuel rail/slowboy street front mount kit
Old 05-05-2006, 12:59 AM
Killa's Avatar
Killa Killa is offline
i just cut that dam cable off on my driver side, so that thing dont hit my head when Im open the door.
GM FOR LIFE !!
NEW 1997 Camaro z28 6 speed
illa never going back to import , but killa alway be nice to any DSM he saw
looking for 2002 Trans Am LSX
UPGRATE 2010 !! 97 Camaro Z28
95 camaro lt1
1992 Pontiac Firebird v6 auto -sold -
Pony 1998 Mustang GT 4.6L Manual. Black
1995 Eagle Talon TSI AWD Turbo manual R.I.P
1994 Mitsubishi Eclipse Manual gray -Sold
1997 Mitsubishi Eclipse RS Auto White - Sold
Old 05-05-2006, 07:07 AM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
I think he wants to take the power seat belts out of his car, not put them in. Every 1g I have seen has those damned power seatbelts. They arent hard to take off at all, my buddy Mike started that the first day he got it. I'm just going to unbolt the track and the motor and disconnect the motor from the wiring harness (I think theres a clip like there is on everything electrical in that car, otherwise I'm just going to cut them). Eventually I want to get a pair of racing seats and I'll put in a harness bar and get a 4pt harness.
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
Old 05-05-2006, 03:31 PM
Yes i do want the power seatbelts! I had them in my old TSI AWD, and i loved them, i know most hate them but i liked them. I sold that car and got this one which is in better shape. It has powerlocks,windows, air,leather seats,came with the stock cdplayer. To my knowledge my came with everything but the sunroof and power seatblets. Perhaps its because its a Laser RST AWD, not a TSI AWD (lasers usually didnt get all the nice stuff), but whatever way i would like to install them. I dont mind doing the conversion, its not the work im worried about, im wondering what all i might need for parts, and where i may be able to get a set, new or used.
Thanks!
Old 05-06-2006, 07:32 PM
1stGenRocks's Avatar
1stGenRocks 1stGenRocks is offline
Send a message via AIM to 1stGenRocks
the nonpower seat belts are the canadian version. you need the belts with brackets, and the a piller and bpiller trim. or you can leave the slotted apiller trim.
shouldnt be hard to find somebody nearby that wants to trade and you can just meet and switch everything.
-1stGenRocks-
95 Tsi AWD: 6 bolt, DSMLink, 880's, ACT 2600, lightweight flywheel, AGX's, Dropzone springs, poly motor mounts and suspension bushings, 3 inch turboback, gus modded 1g BOV, hardpipes, drilled & slotted rotors, 17's
plans: bastard 20g, water/meth injection NO FMIC
