Go Back   Automotive Forums Car Chat > Chevrolet > Monte Carlo
Old 05-04-2006, 09:32 PM
subarutech77 subarutech77 is offline
Unhappy HELP- 97 monte with 3.1
Ok, so I have a 97 monte carlo with a 3.1 - it had a headgasket leaking- so I went ahead and replaced the headgaskets, intake upper and lower gaskets and valve cover gaskets with thermostat- the problem is - I have it all back together and it refuses to start- almost like it is out of time- I did not mess with the timing chain at all- I know the pushrods are different lengths- I've had them out twice and made sure that they were in the correct spot- but when I try to start it, it poofs through the intake at the throttle body- is there anyway that the cam could have jumped a couple of teeth on the chain while I had it apart?? All the valves move normally when the motor is turned over- Please any ideas would be a great help at this point- Thanks
Old 05-05-2006, 08:01 PM
Re: HELP- 97 monte with 3.1
Well, I finally figured it out- on any normal chevy the left bank or front bank is supposed to be the odd numbered cylinders- but on the 3.1 they are the even numbered cylinders- so I had the spark plug wires wrong from the start
I hope this helps someone else- thanks
Old 05-08-2006, 11:35 AM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
easy mistake to make, glad you figured it out.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
