sunbird 500$ thinking about buying
ive seen a sunbird 2 door at a lot for 500 but as i got closer to car on windsheild it said no compression. would i have to replace rins and head gasket if i would decide in buying it? not sure wut year it is. might be a later model. probly a 4cyl. i was wondering could i buy the car casue i own a 91 right now but not likeing the 4 door look. could i posibly drop the engine from my 4 door to the 2 door? mine is a 4cyl. only problem is i don't know if the brackets are the same.
Re: sunbird 500$ thinking about buying
as long as there both 4 cylinders, you should be fine. IF the other Bird is newer (92+) it'll probably have MPFI instead of TBI like your 91. So, you'll need to use the manifold off of the new car.
Otherwise, it should just drop right in. Make sure you replace the rubber engine mounts since you're in there. Good Luck. |
dang car is not their anymore
Good Luck, keep you eyes open. THey pop up for sale all the time. There's a turbo Sunbird in a yard here, complete, that I've been eyeballing... can't get up the courage to go for it though. |
.Why... You getting the itch?? I'm not gonna go for it. Not keeping the bird much longer, eyeballing a 2000 Alero. |
