Go Back   Automotive Forums Car Chat > Pontiac > Bonneville
Old 05-04-2006, 08:51 PM
jjm01o jjm01o is offline
93 SSEi security switch
Can someone please tell me where the switch that controls the security system is located under the dash? I had this replaced 7 years ago and it is acting up again. What happens is I put the key in the ignition, and you just hear a click. After about 5 minutes of locking / unlocking the car with the keyless remote it will finally start. The switch seems to get stuck in an "on" position as if it is activated.
Thanks!
Old 05-21-2006, 08:20 PM
Malachias Malachias is offline
Re: 93 SSEi security switch
Thanks!
JJ01o
Does your secutity light keeps on at your dashboard even with the engine
running?
Malachias (Brazil)
Old 05-26-2006, 10:24 PM
Actually I am not sure. I can't say I've looked. I will check next time. All that happens is you hear when I turn the key is a click, and nothing. After waiting the recommended 10 seconds between start attempts, it will eventually start. Quite annoying. I know the switch is under the dash near the center console.
