Go Back   Automotive Forums Car Chat > Mercury > Mountaineer
Old 05-04-2006, 08:14 PM
tnmk tnmk is offline
where's the Computer module?
Where can I find the Computer module on my '00 mountaineer?
I need to know for the keyless entry code
2000 Mountaineer
2002 PT Cruiser
NGK Iridium
Crane Firewire
K&N
Modified Air Box
Old 06-04-2006, 11:58 AM
jj76ta jj76ta is offline
Re: where's the Computer module?
On the 2000 this may be on the drivers side. hope this helps you.
solved the problem. Well the code for the entry pad for my 2003 Mountnier is on the ecm. The ecm is located behind the rear door on the passenge side. Remove the panel on the inside and you will see it. The panel is just clipped on and no tools are needed. The code is on the White label on the ecm. It is 5 or 6 digets and they are written large off to one side of the lable. After you enter the code it will unlock the drivers door. then push the 3 and it will unlock all doors, then if you want push 5 and the rear glass will unlock. probly some other fetures that it does if you can figure them out. Good Luck.
Old 04-14-2007, 08:08 PM
park7163 park7163 is offline
I have a 1998 and the module was located on the drivers side rear in compartment where the jack is stowed.You will see there are two modules the one toward the front is for the keypad and I found that I had to unbolt it to be able to see the numbers on it.
