Old 05-04-2006, 07:13 PM
Linebckr49's Avatar
Linebckr49 Linebckr49 is offline
Send a message via AIM to Linebckr49
hissing sound
so today driving the car i noticed a nice hissing sound coming fromt the engine. the hissing increases as rpms increase. i thought, "damn, someone musta slapped some turbos on my car during the night!" so ya, my NA now sounds like i'm building boost as i accelerate. so i've got this hissing sound...but i don't really wanna get rid of it....haha.
well its coming from the drivers side, so around the belts & pulleys side of the motor. sound occurs with the A/C off (haven't tried turning the A/C on yet to see if it makes a difference).
--i'm guessing a belt? but i changed my accessory belts 20K miles ago when i did the 60K service. but let's not rule out a squealing belt just yet.
--could it it be a pulley on its last leg?
i'm busy hacking up headlights to do the HID retro-fit right now, so i don't wanna go fishing for this problem just yet. a friend of mine mentioned a possible vac hose leak/disconnected. plausible, but there are no hoses on that side of the motor.
any other ideas?
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
Old 05-04-2006, 08:07 PM
Igovert500's Avatar
blue + red light magnet
Re: hissing sound
lose vacuum hose was my first guess.
Have you had the plenum off recently. Perhaps the gasket is leaking?
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 05-04-2006, 08:15 PM
VR43000GT's Avatar
VR43000GT VR43000GT is offline
Send a message via AIM to VR43000GT
Re: hissing sound
Yeah, I think Linbckr was the one who had his plenum powder coated right? Otherwise it does sound like an air leak somewhere seeing as how it sounds like a turbo.
Now all you need to get is one of those fake BOV sounds that come from the engine. lol
Old 05-04-2006, 08:16 PM
Linebckr49's Avatar
Re: hissing sound
hmm. i DO have a plenum spacer. perhaps i'll see if the bolts are loose and check the gaskets while i'm in there.
93 3000GT base
Old 05-04-2006, 08:19 PM
Linebckr49's Avatar
Re: hissing sound
no, i got my front valve cover powdercoated. but i haven't installed it yet. waiting on the valve cover gasket.
but ya, i hope its a leak rather than a belt/pulley.
93 3000GT base
Old 05-04-2006, 08:29 PM
VR43000GT's Avatar
Re: hissing sound
Ah crap, I had to look it up to be sure. I was certain I remembered you having the penum done. First thing to go is the mind........DAMN, I'm only 18, I'll be senile at 30.
Old 05-04-2006, 08:58 PM
AutostradaVR4 AutostradaVR4 is offline
Re: hissing sound
hmm...have you tried just listening around under the hood while someone tachs it up? I would think it shouldnt be too hard to isolate the sound.
About that plenum spacer, how'd that work out for you? Im looking into one...but i heard someone say they had hood clearance problems.
good luck man
Formerly BlinkRA182
--VR-4-- --09 Lancer RALLIART-- --Me--
Old 05-04-2006, 11:43 PM
Igovert500's Avatar
Re: hissing sound
Linebckr would obviously know from experience. However, I was under the impression, that they really aren't all that great for performance on FI cars. Carbuerated they help more. However, obviously the spacer does reduce plenum temps, which technically isn't a bad thing.
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 05-05-2006, 12:45 AM
Linebckr49's Avatar
Re: hissing sound
Igovert is right about the plenum spacer. it does help to lower intake temps. and theoretically, since it makes the intake runners (tubes) longer, that should help you reach your max torque output sooner in the RPM band. however, its not a very noticeable difference in performance. more of a psychological thing (since installing it, i think it should help me out, so i'm thinking that it must have improved the performance...but not really).
but yes, on a carbureted engine of a couple hundred cubic inches, the plenum spacers DO help quite a lot. b/c of this in NASCAR and other stock car racing leagues, one of the requirements is a specific size plenum spacer (or something to that effect) that limits the max. hp the engine can put out...to make the competition more even.
--> ya i'll have someone tach it up while i listen. shouldn't be that hard to hear. i just have that godawful lifter tick again so it makes isolating the hiss a bit difficult.
93 3000GT base
Old 05-07-2006, 06:30 PM
Linebckr49's Avatar
Re: hissing sound
when i turn the A/C on, the hissing (now turned into a squeaking) definitely gets louder.
do you guys think its (a) belt (b) pulley (c) compressor clutch ??? or a combination of those?
ya, i know i could tear her down and check, but i'd rather just work on the HID retro now, garner your opinions, then check it out.
93 3000GT base
Old 05-07-2006, 07:17 PM
Ralliart 3000gt's Avatar
Ralliart 3000gt Ralliart 3000gt is offline
Re: hissing sound
You might have the same problem as this guy.....
Old 05-07-2006, 09:04 PM
Igovert500's Avatar
Re: hissing sound
I'd check the pulleys and accessory belt.
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 05-07-2006, 09:25 PM
TorchedStealth's Avatar
TorchedStealth TorchedStealth is offline
Send a message via MSN to TorchedStealth
Re: hissing sound
I had a squeak on my last engine that i had in my car. It was one of the pulleys (not sure which one though). It sounded like a BOV especially when it shifted in the high rpm's when i really got on it. Its still in my trunk and i actually think it was either the a/c pulley or underdrive pulley. I lubed some of the pulleys with WD-40 that were visible from the top of the engine bay (without getting it on the timing belt of course) And it went away for a while.
2005 Saturn Ion Redline - Injector Dynamics 1000cc Injectors|E85|Harrop TVS1320 Blower|2.9" pulley|3" Intake|Vibrant Header and catless Downpipe|Hahn 3" catback|N2MB Wot Box w/2-step and no-lift shift|Cobra Heat Exchanger|Hurst STS|Ottp Stage 1 trans mounts|AEM EUGO Wideband|Aeroforce Interceptor|HPTuners (self tuned)|Mop Top Pros Carbon Fiber badges|B&G Springs
